Compensator to solid sproket conversion ?
Old Nov 23, 2016 | 11:43 AM
Big Dave's Avatar
Big Dave
Default Compensator to solid sproket conversion ?
We used to do this a lot on Shovels, and Evos - anyone done this , pro and cons - basic stk 09 ultra if that makes a difference , and any info on where to purchase
Thanks
Dave
Old Nov 23, 2016 | 11:48 AM
vkern83's Avatar
vkern83
Just put one on a 2014 SGS about 1000 miles ago. Been pretty happy with it so far. You can feel the difference. Feels like snappier response. Freed up a couple pounds of spinning mass. Bought it from J&P Cycle and it's made by Twin Power (34 tooth). Upgraded to a Hayden chain tensioner while I had it open to reduce chain slap. I have a welded crank so I don't have to worry about scissoring and having no energy absorption that the compensator used to provide.
http://www.jpcycles.com/product/753-882
Old Nov 23, 2016 | 12:29 PM
Big Dave's Avatar
Big Dave
Thanks for the link
Dave
Old Nov 23, 2016 | 01:00 PM
Redbeard719's Avatar
Redbeard719
I'll be installing an Evolution Industries 30t sprocket very soon, before winter is over. My compensator is making a little racket now.
I also have an S&S crankshaft with Timken bearing. No concerns about the swap and the 30t will make things a little more fun.
Old Nov 23, 2016 | 05:36 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
IF you've done crank work it shouldn't be a problem, stock crank i wouldn't risk it, unless its a pre 02.
Old Nov 24, 2016 | 01:14 AM
Guntoter's Avatar
Guntoter
I'm not sure the spring loaded compensator was meant to reduce crank shock, I believe it was meant to reduce driveline and transmission shock. The concern for me would be transmission gears and bearings along with the primary chain. Maybe they would hold up fine, but just do not know. The primary belt option would be much more forgiving on the drivetrain.
Old Nov 24, 2016 | 07:17 AM
bigdumbnoitall00
their are a few guys in here that ran em with stock crank, thought was as long as u had ids that would take up some of the shock load.
Old Nov 24, 2016 | 09:27 AM
dawg's Avatar
dawg
I ran an EVO Industries 30 tooth in lieu of the stock comp on my 08 ultra for awhile when I was messing around with changing the doggy gearing that was prevalent on the early TC96's. I then changed it out to the original SE version comp and an EVO 49 tooth ring gear conversion to achieve the gearing change. Unless there is a hidden problem lying in wait, it otherwise caused no adverse issues with the stock crank.
Old Nov 24, 2016 | 11:31 AM
wscott's Avatar
wscott
I would think you should be ok with a solid sprocket on a stock bike as long as you dont abuse it doing burn outs ,powershifting & or often going close to or @ full throttle when going thru the gears just about every time getting up to cruise speed.
Its when you abuse an HD & or have a modded motor putting out considerably more pwr & trq running a solid sprocket in place of the compensator that would be much more likely to end up with an issue.
Scott
Old Nov 25, 2016 | 06:09 AM
grbrown's Avatar
grbrown
Wink
The reason it's there is a bit of both - drive-line shocks will go both ways, to crank and primary/trans. These things have been used on bikes going back many decades and on many brands, so someone at some time decided they are a jolly good thing! I have to say I wouldn't run a bike without one.
cdorsey50stang
11
Oct 28, 2015 08:53 PM
Matt Stone
Jun 2, 2015 02:32 PM
stepside
Engine Mechanical Topics
May 20, 2015 09:42 PM
gremlinsteve
Nov 19, 2013 05:20 AM
flsts
Mar 24, 2007 09:28 PM
