Riding warmth
Old Dec 1, 2016 | 08:19 AM
  #61
rv7garage's Avatar
rv7garage
T^2, those look good. Would I want to order a larger size to accommodate longjohns or whatever? In other words, do they size true or are they bigger or smaller than standard sizing? Thanks-
Old Dec 1, 2016 | 08:23 AM
  #62
lionsm13's Avatar
lionsm13
Originally Posted by leadman
I've never thought leather was warm . Starting to think it was just me . I can
keep my upper body warm enough with the gear I have , just working on my
lower half .
Long underwear work good.
Mostly though, just don't ride under your age for a temp and you should be ok.
Old Dec 1, 2016 | 09:46 AM
  #63
T^2's Avatar
T^2
I'm a 35 waist. I got them in 34. Fit perfectly. 36 was too big for me. I don't have any problem with the overpants accommodating jeans and UA base layer (or long johns) underneath. So, no, you want to get them to fit your waist size. You should be good to go with whatever layering you want to do underneath.
Old Dec 1, 2016 | 09:47 AM
  #64
J.Tours's Avatar
J.Tours
Let me start by saying I hate wearing chaps .
If you like the idea of Gaiters but want something designed specifically for motorcyclists; Colorado Chaps offers 'Spat Chaps.'
They are taller and thicker across the front of your leg than a gaiter which will give you more windchill protections. They are also made of ballistic nylon is case of an unplanned dismount.
https://www.coloradochaps.com/
Old Dec 1, 2016 | 10:40 AM
  #65
SWThomas's Avatar
SWThomas
Originally Posted by T^2
As the chaps debate goes....
I use leather over pants. Have the following:
https://www.firstmfg.com/collections...ucts/the-baron
Same conveniences as chaps. They have full length zippered legs down the side and snaps on the bottom. You can take them off and put them on same way you do chaps. No butt or crotch exposed (both warmer and safer). They have normal pockets in front. In back they have one normal pocket and one zippered opening to allow access to your wallet in your jeans underneath. I wear them with jeans and UA base layer. So far so good.
Only issue I see with those is there's no liner. I like my chaps because they have a removable liner. So when I get to where I'm going I can take them off and don't have several layers still on making me hot when I don't need to be. But that's not really a big deal.
Old Dec 1, 2016 | 11:58 AM
  #66
T^2's Avatar
T^2
Suppose you could find lined overpants as well. I didn't look really. For me, it's not really an issue during the colder months. During the season, I don't usually have a destination where I'd be hanging around after the ride (say like riding to work) where having long johns under jeans would become uncomfortable. I usually go out for the ride and return home. One key factor in my choice with these pants was that a local place had them in stock and I could try them on for size. Actually, didn't end of up buying locally though, found them online much cheaper. But when I ordered, I knew the exact size that I needed.
I say all that, but I have actually been a place or two after a ride where I had to stay in my base layer/long Johns and jeans. It was actually no problem and I was pretty comfortable. Each time I had UA base layer (long johns) on. They breath well and are thin/comfortable. Actually, I had caught a little bit of a chill on the rides and was glad to still have the UA's on for a while.
Old Dec 1, 2016 | 12:27 PM
  #67
PalmerAKBiker's Avatar
PalmerAKBiker
I wear Langlitz westerns pull over leather pants. They are expensive, but warm, and keep you dry even in heavy rain. I got mine with 28 inch leg zippers, and they can go on over jeans, or long johns in the late fall.
Old Dec 1, 2016 | 12:48 PM
  #68
Gliden's Avatar
Gliden
This is so true. In the "day" I wore chaps in 30 degree weather and less. I was in my 20's.
Today at 56 I years old i won't ride below 55 degrees. (General rule of thumb)
Not proud of it but.......tis what it is.
Why? Cause I just don't enjoy it anymore and because I don't have to. Lol
Old Dec 1, 2016 | 01:22 PM
  #69
MilesOfTexas's Avatar
MilesOfTexas
I wear fleece lined jeans that I picked up at Cabelas on sale for about $30 a couple of years ago. Love them. Pair them with leather legs gator style chaps and I am comfortable easily into the 20's.
Trick is to not wear layers under them and make sure they fit loosely. This is so they will trap the warmth from your body, just like home insulation and goose down in jackets (loft), to keep you warm. For the leather legs, I bought a 1" extension for when I wear them over the fleece lined jeans. That way they will also fit normal jeans without the extension.
I also wear a Columbia omni-heat jacket liner from my Columbia parka. Between the above and the Columbia liner, I stay toasty warm.
Old Dec 1, 2016 | 03:51 PM
  #70
Almostinvincible119's Avatar
Almostinvincible119
I have to agree to a certain extent. Making a return trip to Florida from NC on my sportbike about 7 years ago when I was 23 and temps dropped (unexpectedly) overnight into the teens. Had to return that day because of work and school. 3 pairs of jeans, my leather jacket, some walmart thermal glove liners and several coffee stops got me into ATL where it started to warm up some.
That rule isn't exact as I know 70 year olds that ride in the 40s-50s...but it's a good rule of thumb
