Posted a few weeks back on here about having my current 96" motor on my current ride, 2008 E.G. Classic/FLHTC, which is stock except for S.E./CVO 255 cams, V&H breather & filter, SESPT tuner, & slip-ons with 2" baffles bumped to a 103 with a S.E. big bore kit, & re-doing the stock heads, mainly due to the high miles, 107-K+ on the current stock set up. Seen a deal over the weekend where an H.D. dealer is selling a 2016 103 take-out engine that came from a customer of theirs who had them install a 120 engine before taking delivery of his new 2016 bike. They're asking less than 3-K for this new motor, it's the air cooled, not twin-cooled engine, the question is if I go for this will the parts from my 2008 96" bolt on to this 2016 103 like the throttle body, primary, tranny, exhaust, etc., or should I pass on this, and do the work on my 96" as I orig. planned.
$800 on head work, $200 on cylinder boring, $350 on pistons and rings, $400 on cams and bearings, maybe add lifters & adjustable pushrods (~$2k)...103 or 107, as opposed to starting with a OEM 103 that still needs headwork and cams, lifters etc..
A new map and tune will be needed, so that cost is the same either way.
I'm not sure if a 2016 would bolt right up and even if it does, sensors and connectors being read by an older ECU/ECM may be a mis-match (thinking knock and MAP).
I would ask the Dealer for a total installed price, and if there is any Warranty??
If the price is too high / no warranty, then I would consider just freshening up the current motor,, as long as the Crank is good...
I second this. Just doing $200 for a valve job, the $200 big bore with $350 pistons gets you to the 103. That's $750 compared to $3000. Use the extra money to get porting done and a high performance cam (another $1500 at most) and you're still ahead $800 and you have a better engine where you can get a good cam and up your compression ratio with some domed pistons. Keep in mind though at a high enough compression you will need releases adding in about another $200 of work and parts.
Should bolt right up, but I would rebuild the original engine as others have said..it seems to have been reliable for you so why not just re-fresh it...that would be the way I would go.
If the low mileage 103 is a simple bolt in on your 2008 model, (this will have to confirmed other that internet chat),, In my opinion it will all depend on what you can buy the 103 for... If it can bought for $2000, or a touch under, I would seriously consider that route...
You can install the se255 from your old bike and save some money while the motor is on the bench , and also use the original pushrods and save some money there..
Now if you can only get the 103 for $3000 , its a toss up whether to freshen up the old motor .... My advice is to bargin hard on the 103 take out, and do your maths..
With that mileage whatever you do to refresh your bike, either rebuild or replace, you will have other costs to take into account, such as primary chain and cempensator, due to wear, possibly clutch. With a rebuild it should be possible to exceed the performance level of a stock 103" and still have spare cash left over.
