Upgrade to stereo
Old Dec 22, 2016 | 04:31 PM
canible's Avatar
canible
Default Upgrade to stereo
Looking to upgrade my 2007 ultra sound system. When i bought it I had a factory installed amp put in it. I beleive its a 140 watt amp. Any way ive been thinking about putting some arc 602 speakers in and wondering if I need to replace the amp. Any input would be appreciated
Old Dec 22, 2016 | 04:41 PM
mkguitar's Avatar
mkguitar
what speakers do you have now?
very basically the specs on speakers count for alot-
the most important is sensitivity- usually expressed as a number like 92dB 1watt/1meter- that is a good spec, but 95dB would be almost twice as loud for the same volume settings...88 dB would almost be 1/2 the apparent volume.
so the specs on the ARC602 are 88 dB per watt at 1 meter.
other speakers rate higher sound output- the polk MM651* are at 92dB, the Kappas are at 95 dB.
this tells us that the kappas would be way more than twice as loud as the ARC at the exact same volume setting
so it's the way you use the power your amp is putting out- a "watts" rating on a speaker tells us how much power they can accept- not how they turn that electricity to sound
( and that can lead to "the ARC;s are great and you need a bigger amp"- a $100 project turns in to a $400 project)
2nd, frequency response; some speakers are all midrange and tinny- you want a speaker which reproduces frequencies evenly...lows, mods and highs.
I've been involved in concert sound systems for 40 years- most of my riding is done with pro earbuds wired into the stereo ( noise out, music in), but I have been 'sperimentin' with my stereo- i have tried the J&M and have a set of kappas going in tonight or tomorrow
I do my own tests with ear and also tone generators to check the sensitivity and frequency response..I am also trying to treat the inside of the fairing cavity
Mike
I have another thread detailing fit issues with polk MM651UM vs MM651
Old Dec 22, 2016 | 04:42 PM
Little Mike's Avatar
Little Mike
You're going to get much more information if you report this over in the audio section. A lot of helpful and knowledgeable guys over there who are very willing to help. Quick assessment though. ARCs are good speaker but you are definitely going to want to upgrade your amp.
Old Dec 22, 2016 | 07:14 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
amp ratings can also be deceiving, 140 watts peak or rms, also have to look at ohms.
Old Dec 22, 2016 | 07:15 PM
0ldhippie's Avatar
0ldhippie
I forget what amps went with what years but ya really need to know what ohm speakers the amp will work with if you plan on keeping your amp. There may be smoke waiting to escape in there. The audio section is your friend...
Old Dec 22, 2016 | 07:22 PM
Uncle Larry's Avatar
Uncle Larry
There may be smoke waiting to escape in there ...and it's extremely difficult to put the smoke back in, trust me!
Old Dec 23, 2016 | 07:01 AM
sbeast's Avatar
sbeast
the "factory" amps are garbage. toss it out and invest in a decent aftermarket one (Rockford fosgate PBR300, Arc mini, etc) along with some good speakers (folks on here tend to prefer infinity kappas)
Old Dec 24, 2016 | 02:41 PM
mkguitar's Avatar
mkguitar
thoughts on J&M 7'25's and Kappas:
https://www.hdforums.com/forum/audio...l#post15779471
Mike
rdc401
Audio Systems
Oct 29, 2017 08:49 AM
NVERL8
Audio Systems
Feb 25, 2017 05:19 PM
RC07ultra
Audio Systems
Apr 26, 2015 10:22 AM
bayboy75
Audio Systems
Apr 5, 2015 04:16 PM
rkoener
Audio Systems
24
Jun 12, 2014 01:10 PM
