Snap ring pliers
Old Jan 30, 2017 | 08:49 PM
VA_Larry's Avatar
VA_Larry
Default Snap ring pliers
Any tips on where to find snap ring pliers that will remove the retaining ring on the clutch handle?
I have a set of pliers that I've used on other vehicles but the holes in this particular snap ring seem to be too small for the pliers points to be inserted.
Is there a "mini tipped" snap ring pliers that are needed for this?
Old Jan 30, 2017 | 08:53 PM
sanman4ever's Avatar
sanman4ever
The pair I use have removable tips, sizes and angles. Home depo or Lowe's I got them from.
Old Jan 30, 2017 | 08:55 PM
caulk04's Avatar
caulk04
There's many options out there. I happen to have a Craftsman set that has three different sized handles each capable of internal and external rings and having interchangeable tips etc etc. Very handy...
Perhaps not the help you were looking for, but it's not a specialty thing.
VA_Larry's Avatar
VA_Larry
The set I have came from HF but I looked at Home Depot, auto parts stores, and Ace Hardware. All seems to carry the same set with different packaging. All of the tips were the same size.
TriGeezer's Avatar
TriGeezer
Yeah...I got mine from O'Rielly Auto parts, for about $15.
But, I'm sure there is an official HD branded one available at your favorite HD dealer for $249.95.
Old Jan 30, 2017 | 08:58 PM
bad tappets's Avatar
bad tappets
I have an old Craftsman set, with interchangeable tips. Either that or you'll have to buy a couple of different sizes, esp for the real small snap rings.
Old Jan 30, 2017 | 09:04 PM
TI06's Avatar
TI06
I used a dremel and ground down the tips to a nice point. I was having the same problem as you were, finding tips small enough to fit. It only took me a couple minutes.
Old Jan 30, 2017 | 09:05 PM
97stalker's Avatar
97stalker
Harbor Freight. Have worked well...
Old Jan 30, 2017 | 09:17 PM
PistolPete83's Avatar
PistolPete83
any pair i had have different attachments..diff sizes
Old Jan 30, 2017 | 09:20 PM
Jaystn62's Avatar
Jaystn62
I have a Channel Lock brand set that have many different sets of interchangeable tips in straight, angled and 90 degree. Also can be switched from internal to external. I think I paid less than $30 for the kit.
