Security light wires
Old Feb 10, 2017 | 06:47 AM
trappermarc's Avatar
trappermarc
Default Security light wires
13 FLHX. I am thinking about adding a security led under the fuel tank, that will flash along with the red key light in the dash. A little colored light flashing on the engine chrome. I would use a small led, so draw should not be a problem. I just can't find a wire diagram that shows which wire it is. I've done a search and have a repair manual. The manual doesn't show the security light. I could back probe the wires in the cluster, but would rather just find one in main harness around fuse block.
Old Feb 10, 2017 | 12:38 PM
mkguitar's Avatar
mkguitar
you could just buy a simple led with a flasher built in if that what you want $5
looking at my wiring diagrams I see a serial data which I think is used to control the sec light- but not sure
mike
babaharley
Mar 17, 2018 07:02 PM
wickiupwarrior
Electrical/Lighting/Alarm
May 28, 2013 11:20 PM
rockchalk08
Mar 28, 2011 06:56 AM
Slayer
Mar 20, 2007 11:24 AM
05 Ultra
Feb 15, 2006 11:22 PM
