broken fairing brackets
Old Mar 12, 2017 | 08:35 PM
mike canuk's Avatar
mike canuk
Default broken fairing brackets
Did anyone have the brackets in their fairing break ?
Old Mar 12, 2017 | 08:42 PM
1957buick's Avatar
1957buick
yes on my 08 ultra, harley has an updated set no problem with new ones
Old Mar 12, 2017 | 09:13 PM
EG-2006's Avatar
EG-2006
Many here (including myself) have repaired the broken bracket by adding a 90 degree angle steel bracket used for furniture, etc from Lowes/Home Depot type stores. Lay the new bracket in place, drill some holes, add some nuts and bolts and you're done worrying about this problem. This takes care of the center brackets.
On my 06 there are also braces that extend out to the speakers that were also broken at the speaker end. Had a guy at work weld the end back on and also reinforce the end with a small piece of round bar. These 2 repairs have worked well and without further issues for the past 40k miles.
Old Mar 12, 2017 | 09:56 PM
Buzz 3's Avatar
Buzz 3
Kept blowing headlight bulbs and Dealer rep told me to check the brackets. Sure enough one was broken. Replaced both and still using same bulb 3 years later and 20K miles later. Easy fix with new brackets. Not that expensive either.
Old Mar 13, 2017 | 12:00 AM
LQQK_OUT's Avatar
LQQK_OUT
Old Mar 13, 2017 | 12:08 AM
t. sawyer's Avatar
t. sawyer
07 sg both replaced.
Old Mar 13, 2017 | 06:21 AM
todd-67's Avatar
todd-67
I had it happen twice to my 09 before I got the revised brackets. They fixed the problem.
Old Mar 13, 2017 | 06:35 AM
DamifIknow's Avatar
DamifIknow
06 broke and fixed like EG-2006. Not a problem again. Not a issue on my 2012 limited yet.
Old Mar 18, 2017 | 07:58 PM
Our07Ultra's Avatar
Our07Ultra
I went to Ace Hardware, got 2 pieces of aluminum angled pieces and made my own 7 years ago. Still holding strong!!
Old Mar 18, 2017 | 10:29 PM
pingman68's Avatar
pingman68
I finally went with the Strong Arm brackets, no worries now.
