The All things ROAD KING SPECIAL THREAD
Old May 3, 2021 | 07:53 PM
  #2641
Pablo22's Avatar
Pablo22
Originally Posted by Oil, Gas & Leather
That is B. S.!! The cluster F*&k is ON THEM for subbing parts without your permission...UNLESS you said "ok let's do it"! Curious minds just gotta know...who is it??
High Desert Harley in Meridian, ID. The owner called me and promised me 1. My money back for the Smart Tune that doesn't work with the 131/ecm. 2. a free 5K service. 3. A free 10K service. This was all before I even knew there was an issue with the riser. When the parts dummy asked me to go in half I couldn't believe it. Not only do they got some nerve - they have ZERO class!
Old May 4, 2021 | 09:28 AM
  #2642
Oil, Gas & Leather's Avatar
Oil, Gas & Leather
Time to move along from that one. That relationship is soured & needs to be tossed in the garbage!
Old May 5, 2021 | 11:00 AM
  #2643
ThePaintPirate's Avatar
ThePaintPirate
Went on a charity ride with one of our semi-local MC groups, only RKS around.
Old May 5, 2021 | 11:21 AM
  #2644
Arby24's Avatar
Arby24
Been slowly doing upgrades this spring.
Swapped out the ignition switch and installed the RoadThunder speaker
New air cleaner. Re-tuned with V&H FP3
Next in line:
Flush mount gas caps
Muller HydroClutch
Waiting on delivery for a new seat and then can get measured for new bars.
Old May 5, 2021 | 12:23 PM
  #2645
Keggr's Avatar
Keggr
Finally got my bike after two and a half long months of waiting. I have a question for anyone running Carlini 1.5" bars - what riser/handlebar clamp are you using. The dealership installed an LA Choppers clamp on mine and the bars can be pulled back no further than you see in the picture. Tech said if he pulled them back any further it would pinch the wires coming out of the bar? Any help would be appreciated.
This may sound stupid, but did he by chance put the top clamp of the riser on 180 degrees backwards? The hole patterns are symmetrical and maybe there is an indentation on the other side of the plate that would allow more room for the wires when you rotate the bars back........
File Type: pdf
Old May 6, 2021 | 09:02 AM
  #2646
beardedlaugh's Avatar
beardedlaugh
So I'd like to replace the chrome fuel gauge and gas cap on my '21 RKS and I came across this kit from H-D (https://www.harley-davidson.com/us/e...it/p/75027-08D) but it says it works for '08-'19 Road King models. Has anyone tried it on a '20 or '21 model? I can't see why it wouldn't work, but I thought I'd ask before I start screwing with stuff.
Old May 6, 2021 | 09:08 AM
  #2647
Bloody Marvelous's Avatar
Bloody Marvelous
They don't update every add-on part compatibility every year. The tank hasn't changed since 2008, so these are guaranteed to work on 2020 and 2021 models as well.
Old May 6, 2021 | 11:17 AM
  #2648
GreenMonster's Avatar
GreenMonster
Rks hasn’t changed so they should fit .
Old May 6, 2021 | 11:28 AM
  #2649
Xcrossbow's Avatar
Xcrossbow
You should be good to go since under the reviews for your link one of the poster wrote -
"Perfect match on my 2020 Road King Special!
SWEEPSTAKES ENTRY
This just made the tank on my FLHRXS look so clean,smooth lines. Took me about an hour to install myself. Great addition to the blacked out bike!
Big Dee - Kinsport,TN. - Motorcycle: 2020 Road King special
Add a comment
Helpful? Yes (5)"
Old May 6, 2021 | 11:33 AM
  #2650
username not valid's Avatar
username not valid
Be careful with that kit. The trim ring for the fuel cap does not like fuel. This is what happened the first time I removed the cap at a gas station on a hot day and the vapors hit it.
