High idle
Old Apr 28, 2017 | 08:48 PM
Greg1's Avatar
Greg1
Stage I
Default High idle
Have a 2017 flhx have about 1300 km, today when i start my bike the idle did not come down below 2500 and even went at 3000, what is to be the problem
Old Apr 28, 2017 | 09:14 PM
hog-doc's Avatar
hog-doc
Haven'tseen that happen on an M8 yet!
Old Apr 28, 2017 | 09:16 PM
liquidr1's Avatar
liquidr1
check the harness connector on the throttle body. unplug it and plug it back in and make sure its on all the way. If that doesn't fix it, take it to the dealer. Under warranty.
Old Apr 28, 2017 | 09:50 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Turn ignition switch to off. Turn kill switch to run. Rotate ignition switch from off to ignition. The yellow check engine will turn on for a few seconds then off. As soon as the light turns off turn ignition to off. Wait a couple seconds and repeat. Do this four or five times and this should reset the idle. Start the bike after this process and you should be idling normally again.
See if that helps you out.
Old Apr 29, 2017 | 07:30 AM
Vernal's Avatar
Vernal
Old Apr 29, 2017 | 07:35 AM
Iceman24's Avatar
Iceman24
She's shot...I'll take it off your hands for $500 and a one-way plane ticket.
Old Apr 29, 2017 | 07:50 AM
HKMark23's Avatar
HKMark23
This a temporary or sudden condition ? Was your engine hot at the time ?
Could be vapor lock. Ease out the clutch when this happens and the idle may just drop to normal under a temporary slight load. I sometimes get this under hot conditions, generally right after a refuel stop.
trackadaptor
Apr 9, 2021 08:46 AM
Teroy
Sep 29, 2015 11:22 AM
jbasile
Jun 25, 2015 03:51 PM
DCWC
Feb 28, 2010 11:48 AM
thehueg
Aug 7, 2008 03:22 PM
