Ultra Electrical Issue
Old May 11, 2017 | 09:16 PM
DaddyKnuck's Avatar
DaddyKnuck
Default Ultra Electrical Issue
Interesting thing happened tonight on my 2012 Ultra. Heading to a meeting about 20 miles from home, when the engine and battery lights came on. As I was turning around to head back home, the ABS light came on. Volt Meter on the bike indicated it was charging at 10V even at highway speed. By the time I got back to the house it was running rough.
When I got home from the meeting, it started up and ran fine. No warning lights and charging at 14V. Probably unrelated, but sometimes the neutral light doesn't light when it should.
Battery is new this year and the cables are connected tight. Any ideas?
Old May 11, 2017 | 10:33 PM
mkguitar's Avatar
mkguitar
make sure your voltage regulator bolts are clean and tight.
cables at the other ends?
the tech board has a sticky on testing the stator and regulator- as does the service manual
mike
Old May 12, 2017 | 04:27 AM
grbrown's Avatar
grbrown
The bike voltmeter isn't very accurate, so use a multimeter to check numbers. As Mike suggests, run the charging system checks, as your symptoms are typical of a charging fault. That 10volts may be battery voltage, not the charging system if that has failed. Check the main cable connections at both ends, not just the battery, also the ground strap, if your bike has one (between engine and frame).
Old May 12, 2017 | 04:34 AM
jdw1's Avatar
jdw1
On a 12, I guessing it's a voltage regulator. Jmo.
Old May 12, 2017 | 07:32 AM
05UltraBob's Avatar
05UltraBob
Yep.....Either that or stator.
Old May 12, 2017 | 07:34 AM
im's Avatar
im
Get a digital voltage meter.
Charge battery.
Then do the test of at rest, cranking and then high idle.
Then attach meter to bike securely and then drive only as far as you are willing to push or have someone follow you with jumper cables or take one of those small jump packs with you..
There is a possibility your regulator is failing at higher RPMS.
Old May 12, 2017 | 09:14 AM
Duracell's Avatar
Duracell
In my limited experience (I'm on my second stator & third VR and I've changed a few out for others) it seems the voltage regulator is almost always an intermittent issue at first. Stators not so much.
Napalm Dog
Aug 26, 2014 05:11 PM
Junior in NE
Aug 18, 2014 06:44 PM
WrenchinRider
Aug 10, 2013 08:28 PM
fabricater
Jul 2, 2012 10:16 AM
Streetrunner
Aug 23, 2009 08:06 AM
