Stator or regulator?
Old May 16, 2017 | 12:16 PM
ORradtech's Avatar
ORradtech
Originally Posted by Keithhu
Latest update for anyone that cares. They opened it up today, stator definitely hosed.
Also compensator spring pack. No big deal on that, ~$90 part, no labor, of course.
I'd wonder about the regulator as well. You had high voltage spikes. The VR is supposed to limit output to 14.2ish volts. Spikes means it's not. My suggestion is to be sure they check and verify it's working right. You don't want to trash a new stator.
Old May 16, 2017 | 12:52 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Stator and regulator tend to go at about the same time. I did not replace the VR at the time I changed my stator on my Buell and ended up replacing the VR a month later.
You're saying the stator is only $90? Mine was over $200 and wasn't as large.
Old May 16, 2017 | 01:22 PM
Keithhu's Avatar
Keithhu
No, I'm saying the compensator spring pack is $90
Old May 18, 2017 | 11:49 AM
Keithhu's Avatar
Keithhu
Final update on this.
Note shorted coil section of the stator at 12 o'clock in the picture.
Also bad compensator spring pack caused wearing on the rotor. So, new stator, rotor, spring pack, and they used the VR I had purchased to replace the old one (after a test ride, voltage still bouncing around).
Total parts and labor = $1K
vicsponjr
Sep 15, 2019 06:24 PM
mack03
Jul 17, 2015 06:51 AM
FL-kruzen
Mar 28, 2012 06:46 PM
4whlndeb
Jun 11, 2011 11:24 AM
04nightrain
Mar 17, 2011 06:15 PM
