Low rear tire pressure - help finding cause??
Fast forward to last saturday - (3 weeks or so after last pressure check / 2-up ride). Went on a short ride to grocery store - had a moment where bike felt a little squirrely in a tight-ish 30mph turn - but road surface was patched and uneven, and my line wasn't quite right and passed over the joint between old road and newer patch - chalked it up to rusty riding. When walking back to the bike after the store, the rear tire did look somewhat low - but didn't have a pressure gauge with me, so I rode home. Should have checked it when I got home, but didn't. Then yesterday I finally had a chance to ride to work - pulled the bike out, and checked the rear. it was down to 8 psi. HOLY $#!T. Figured I had to have picked up a nail or a screw or something.
Didn't have time to do a thorough check before work, so pumped it back up (to 34 psi, cause that's what I got to, being aggravated), and took the truck. Got home, it was still at 34. Pumped it the rest of the way to 40, and left it overnight. Still at 40 this morning. Finally got a chance to put it up on the jack and really look it over - turned it over 5 times, can't find a single sign of damage/puncture/debris in that tire. It DOES feel to the hand like it's got some mild uneven wear. Don't think it was like that last year, but honestly wasn't paying that much attention. Took it out for a a few miles today, seems to be holding pressure, and I can't feel anything odd. My guess is I've been running at least somewhat low for the past couple weeks (causing some mild choppy wear). I did not really feel anything dramatically bad in the way of handling though.
What the heck could have caused a fairly rapid deflation (40psi to 8psi over roughly 3 weeks) besides a puncture? Outside air temps are a little warmer than 3 weeks ago. Front tire is still where I put it (well, acutally 0.5psi higher). What the heck else could cause this? Nobody has access to the bike to let air out of the tire (it's locked in my shed). I'm stumped??
Any suggestions on things to check? At this point, my plan is just to monitor pressure before and after every ride, and only do short distance / low speed stuff until I re-build some confidence in the tire.
Thanks
Dan
Check stem and valve core, too. The bubbles will show it. Inflate to 40. Check treads, too.
Some small leaks will leak more depending on how it is parked. Heck, if you have to, put a big container of water under the tire and lower some of the wheel into the water.
You will find it. Some leaks can be very tiny.
if you rode it much at 8 psi, I'd be concerned about the tire carcass. Particularly the sidewalks.
Kept looking & found both tires had been plugged by
previous owner . Bike only had 4,000 miles on it when
I bought it . I was not happy .
Ben
to intermittent air loss. Things happen. The universe is just reminding you and all
of us to check tire pressure. You can no longer tell by looking. 8 psi. Been there.
Every vehicle I have has a gauge handy.
Although I admit, my first thought was an old movie and I can't remember the name or even the storyline except that there was this accountant type geek who had a neighbor that loved to screw with this guy. Knowing that he (the accountant type) would meticulously keep track of his mileage, the neighbor would siphon gas from his car one week, only to put it back in sometime later, after the accountant would have refilled and checked his mileage. The accountant was totally frustrated as one week he would get 32 miles to the gallon, only to check the next week and down to 12 miles to the gallon. Then a week or two later back up to 36 or whatever.
So does you neighbor have access to your bike?
I bought a "FOBO bike" TPMS. I haven't got to use it since the bike is apart for engine upgrades. You can see, on your phone, what you tire pressure is. You can set high and low pressure alarms. Just my attempt at being more diligent about my tire pressure. I hate laying in the driveway checking it before heading out.
The front is easy enought to add but the back is a pain and definitely installing 90 degree stems next set of tires
