Engine temp sensor removal
Old May 15, 2017 | 11:47 AM
glsec507's Avatar
glsec507
Default Engine temp sensor removal
I'm trying to replace my engine temp sensor on my 06 road king. I removed the horn and unplug the sensor and I have a deep socket which I can get to go over the sensor but it seems there is no way I'll be able to then attach a socket wrench to the socket. There is nearly zero room between the end of the socket and the rear cylinder.
Anyone who has done this have any suggestions? Are there tools out there that will get into the tight space?
id rather not give a shop labor costs to replace a little sensor.
Old May 15, 2017 | 06:24 PM
Boomer1143's Avatar
Boomer1143
I changed mine without removal of the horn. I used a deep socket with a 12 inch extension. The extension has a built in wobble of 15 degrees. The hardest part for me was getting the wiring plugged back in.
Old May 15, 2017 | 06:28 PM
QC's Avatar
QC
Yup, an extension is the answer.
Old May 15, 2017 | 06:46 PM
glsec507's Avatar
glsec507
Great I'll try the wobble and extension.
Old May 16, 2017 | 02:49 PM
glsec507's Avatar
glsec507
Used one of those wobble/pivoting adapters with an extension and had it swapped out in 5 minutes.
Thanks for the tip! Hopefully someone else finds this useful as well.
mke125125
Oct 27, 2023 07:53 AM
bobalou1999
May 25, 2021 07:31 PM
Mpbrink5
Engine Mechanical Topics
Jun 23, 2014 10:54 AM
jmr1971
May 24, 2014 09:11 PM
alazlo
Jun 11, 2007 01:49 PM
