Ticking when not under load
Old Jun 9, 2017 | 12:06 PM
cajun1957a's Avatar
cajun1957a
I can tear an ironhead sportster engine down and up again in my sleep, same with a shovel, but these twin cams scare me. Too many little parts.
randy
Old Jun 9, 2017 | 12:54 PM
predatornut's Avatar
predatornut
I had a small oil leak on the rear rocker box base so I decided to install rockouts and replace the lifters while I had it mostly torn down anyway. I will say they did make a difference but did not eliminate the ticking completely. Maybe it is caused by something else, I don't know. It was worth the $16 definitely, but I wouldn't go through the trouble unless I was tearing into it anyway.
Old Jun 9, 2017 | 01:34 PM
ROCKOUT Rocker Products
Sponsor
Originally Posted by mkguitar
have a look at the instructions- it is a pretty quick basic job.
Mike
^^^ This
Full instructions are on my website... it's a simple job really.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 9, 2017 | 06:26 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
randy
If you can do that...
You can do this. It's really no big deal.
I believe many here have done it without pulling the tank.
Old Jun 9, 2017 | 07:29 PM
predatornut
You don't have to pull the tank completely, but you will have to unbolt it and lift it. A 2x4 under it will keep it out of your way. It is really quite easy. Just make sure the cam is on the base circle before you pull the rockers. You do have a service manual, right?
lhgdale
Mar 5, 2019 01:18 PM
JeffJA
Engine Mechanical Topics
Jul 6, 2018 02:23 PM
cajun1957a
May 29, 2017 07:03 AM
dforeid
Mar 21, 2017 08:00 PM
gipper
Sep 30, 2013 12:21 PM
