Ticking when not under load
Old Jun 8, 2017 | 07:22 PM
cajun1957a's Avatar
cajun1957a
Default Ticking when not under load
So, if one hears that ticking when the bike is cruising and not under any load, does that signify perhaps it needs these Rocker Shaft Inserts. I have recently, since installing cams, noticed it but never when there is a slight load on the motor. Only when its turning freely running down the road at 80 kph (50 mph) with no load. I don't hear it five above or below. Just an observation. 2003 Road king classic 38,000 km.
randy
Old Jun 8, 2017 | 08:07 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Those rocker shaft inserts seem the most trusted fix for the "singer sewing machine syndrome". I some times if I let the bike warm up a little the ticking is less severe. My 02 has the hybrid cam plate and improved oil pump, it's not as bad as the '13 and my 05 is good as gold. Wish HD would accept this remedy and recall or at least a TSB. IMHO it's HD's sloppy tolerances.
Old Jun 8, 2017 | 09:15 PM
ROCKOUT Rocker Products
Sponsor
The tapping at cruising speed is the most common symptom, but it can come at any RPM.
Have a look around my website
John @ Rockout
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 8, 2017 | 10:59 PM
Veekness's Avatar
Veekness
I put 'em in my 96...best sixteen bux I ever spent! Worth a try no matter what...
Old Jun 9, 2017 | 09:05 AM
cajun1957a's Avatar
cajun1957a
Does anyone know of a good wrench near Windsor Ontario, (Canadian Side) that has installed these inserts that I can hire to do them?
Randy
Old Jun 9, 2017 | 09:54 AM
mkguitar's Avatar
mkguitar
why wouldn;t you use someone on the MI side?
Mike
Old Jun 9, 2017 | 10:37 AM
cajun1957a's Avatar
cajun1957a
MKguitar, I'm Canadian and not about to take my bike across the border and leave it to be worked on. Unless they could do it immediately while I wait, it just wouldn't be wise or economical.
randy
Old Jun 9, 2017 | 10:50 AM
mkguitar's Avatar
mkguitar
have a look at the instructions- it is a pretty quick basic job.
just thinking why not cast a net to the widest talent base you have available.
Mike
Old Jun 9, 2017 | 10:57 AM
SBates08's Avatar
SBates08
Mike
I agree. It's an easy enough job to do yourself and like Veekness said, it's the best $16 you'll spend on your bike and it'll get rid of that annoying tick.
Old Jun 9, 2017 | 11:16 AM
xcbullet's Avatar
xcbullet
It was apart to do cams and it should of been done then. I wouldn't take motor apart for inserts . It just sound & doesn't hurt anything.
