Sound and Lope
Old Jun 23, 2017 | 07:06 PM
Fine09's Avatar
Fine09
Default Sound and Lope
When I start my 09 RK it sounds like an outboard motor on a boat - a fast whop-whop-whop. Once it is in gear and warmed up, it slows down a little but still doesn't sound like the Harley "potato-potato-potato" sound. This past winter I changed a lot of things on my bike - including a new 2-into-1 Rush exhaust and swapping the stock cams for the OEM SE cam. It didn't give me the results I wanted.
About a year ago, I remember reading someone's thread who said that you would never get one of the newer motors to produce the potato lope. Somehow I don't believe that. It seems that it is just a matter of combining the right exhaust (sound) with the right cam (lope). Am I missing something here?
Old Jun 23, 2017 | 07:55 PM
Beak's Avatar
Beak
The advent of Fuel injection took away some of that. But the older Carbed bikes Idled lower, the new bikes idle at 1000 rpms, the old Evo's would idle about 850-900. Plus the cams they use with the carbed bikes gave them that distinctive sound. The EFI bike cams don't have the same lope at idle.
Old Jun 23, 2017 | 07:57 PM
mkguitar's Avatar
mkguitar
I swear I'm gonna start selling cd's of my panhead idling!
so here's a screenshot of the idle speed setting on my 09- these are somewhat edited by me:
the high idle is a required as the oil pressure and volume being rpm dependent- the oil is part of the cooling system
the twin cam also has light flywheels- which means less forward rotational force os stored- the upside is that this makes for a much faster revving motor
3.) emissions will be lower at a higher idle- better efficiency, more complete burn-
the designers want that as the reduced tailpipe emissions at idle will allow more cam from the factory
my '53 will idle and even pull me around at 600 rpms- a big part of that is the manual ignition advance- on the old bikes the rider advances by pulling the left grip back, retards by rolling it forward.
a retarded advance will have more of a pop, the later spark timing will give more torque
and the classic bikes have alot more flywheel
so upgrade your amp and speakers- and buy my cd!
it'll sound great.
mike
Old Jun 23, 2017 | 09:00 PM
Yamaharley's Avatar
Yamaharley
Dam Mike that's funny. The op could always buy a shovel? Even the evos still sound cool. Who cares if the twin cams sound like metrics, it says harley on the tank.
Old Jun 23, 2017 | 09:12 PM
Fine09's Avatar
Fine09
I have no idea what my idle rpms are right now since there isn't a tach on the bike. This past winter I had a Power Commander 5 installed and the bike tuned by a local indy shop. I could always run it by their shop and have them compare what's on the bike to your settings.
Old Jun 23, 2017 | 09:54 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The 1000 rpm requirement also is there for the charging system.
Old Jun 23, 2017 | 11:22 PM
0ldhippie's Avatar
0ldhippie
Ya can turn the idle down and fatten it up with a proper tuner. Not sure it is a good idea with light the pressed cranks...
Old Jun 23, 2017 | 11:25 PM
Veekness's Avatar
Veekness
One of the big reasons you won't get the classic Harley idle...in addition to what others have said...is that the Twinkies are set up with single fire ignition. No waste spark. Two Harleys ago, my engine was a cone shovel bottom end and a pan top end with dual plugs STD heads...and a single fire ignition. Noticeably smoother running engine and maaaaybe a smidgen more power...but definitely no potato potato idle. It was an acceptable tradeoff.
​​​​​​​You want a potato idle? Get you a blockhead or older, set yer idle down to 400 to 500 RPM...and cackle that sumbitch to yer hearts content.
Old Jun 24, 2017 | 01:11 AM
Zerk's Avatar
Zerk
Cam it.
Cams have changed with EPA.
Lowering idle may not be good for your bike. Need to keep oil and voltage up. Harleys sells cosmetic and nostalgia. You think they turn the idle up because they want to go against fluffy stuff like that?
My carbed machines, I typically turn idle up, less stalling. I can afford an extra gallon gas per year. Maybe you can't
No.
Blockhead never caught on, and its not a shovel. Don't pretend it is somethign thing it is not ,but calling it a funny name. 400-500 idel is just silly.
Never listen to anyone who says blockhead.
Old Jun 24, 2017 | 01:25 AM
Chekoz77's Avatar
Chekoz77
Something like this is probably as close as you will get without opening the motor up.
