Random diagnostic code help!
Old Jul 19, 2017 | 02:00 PM
DaveRidesBikes's Avatar
DaveRidesBikes
Stage I
Default Random diagnostic code help!
Hi everyone! New member here and desperately seeking help that no one can seem to tell me anything about!
I'm riding a 2010 Street Glide that has a full set of Dakota Digital gauges which is getting a weird code that neither my local dealer or Dakota Digital can find any info on... I was riding back from the mountains Sunday and I had been on the bike about 3.5 hours and was about a mile from the house when underneath the tachometer started showing "Bus E1" then a couple seconds later it said "Bus E5" then it went away. This morning I pulled the bike out to wash and when I was letting it run afterward it showed "Bus E0" again and the tachometer was stuck at 1000. I rode it around the hood a bit and it stayed at "Bus E0" that time.
I put it back in the garage and pulled the main fuse and disconnected the battery to try and clear it and see if it happened again. When I turned the bike back on it immediately went to "Bus E-" and the tachometer stays at 000 even when running.
I've checked the diagnostic codes and also have an ABS light on. I've got codes U1097 and C1021 showing up, but my speedometer still works so the U1097 doesn't make sense.
Someone please help me make sense of all of this! Thank you!
Old Jul 19, 2017 | 04:40 PM
kojak's Avatar
kojak
Most probably your front wheel speed sensor is bad, would also cause your abs light to come on. Bus E codes are probably something to do with the gauges.
Grey_Beard
Apr 13, 2019 01:40 PM
tomcatg
Jul 2, 2018 07:29 PM
Tedjay
Jul 9, 2016 04:59 PM
pled55
Aug 11, 2013 03:00 PM
wikd
May 23, 2010 08:42 PM
