Squirmy
Old Sep 23, 2017 | 11:20 AM
Roadking Skip's Avatar
Roadking Skip
6th Gear
Default Squirmy
As of late, the rear end of my 05 Roadking feels a little skiddish going down the road and especially over tar strips etc. Any help?
Old Sep 23, 2017 | 11:50 AM
Keithhu's Avatar
Keithhu
Check the following 1) front motor mount. They are known to shear like a sliced bagel 2) tire inflation 3) spoke tightness if you have spokes 4) rear shocks may be shot 5) steering head bearing
All, or some of the above could be at work here
Old Sep 23, 2017 | 11:52 AM
MotoJockey's Avatar
MotoJockey
Lift that puppy up in the air give the swingarm a good shake to see if you have any clunking going on. My 03 RK started doing what yours is doing recently and I found out I needed new swingarm bearings and mounts. I did the front motor mount as well since the swingarm mounts are 1/2 of the motor/tranny mount system. Much better now.........
Old Sep 23, 2017 | 11:53 AM
skratch's Avatar
skratch
wow, sure could use a little more info. how long have you had that rear tire? how is the tire pressure? what brand/size tire is it? what about the maintenance on your bike, are you up to date? steering head bearings, etc?
Old Sep 23, 2017 | 12:57 PM
cncmike's Avatar
cncmike
Definitely check the tire pressure first. Then tire age, steering neck bearing adjustment and wheel bearings.
Old Sep 23, 2017 | 01:25 PM
Keithhu's Avatar
Keithhu
Mark my words, it's the front motor mount
Old Sep 23, 2017 | 08:04 PM
Roadking Skip
6th Gear
Thanks to all of you for your help. Spokes are tight and ting like bells. Motor mount was replaced last year. Tire pressure right on the money. Rear wheel alignment is within 1/16 of an inch. Seems to be no noticeable play at swingarm or steering neck bearings. AHhhhhhhhhhhhhhh. Wait....here it comes. Double checked TWIs on both tires with a good flashlight and low and behold, both Metzelers are showing wear bars. Rear is the worst. Will ride til late fall and replace both before spring. 11,000 on rear(4 yrs old) 16,500 on front(approx.5 or 6 y.old). Hope that's all it is. Thanks.
Old Sep 24, 2017 | 11:25 AM
Veekness's Avatar
Veekness
By "showing wear bars", do you mean that the treads are worn down TO the wear bars? That's the indication that the tires are all done, replace tires now! Not late fall!!
Just sayin'...
Old Sep 24, 2017 | 11:31 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Get rid of the stock air suspension. It is a poor excuse for suspension when new and only gets worse. Replace with good Tuned coil overs and you will be amazed! Check your swing arm bushings also as well as your tire and bearings.
apetterez
Apr 5, 2015 09:23 PM
jeemann99
Apr 4, 2015 02:31 AM
PGDredd
Aug 28, 2010 12:21 PM
Mr Wonderful
Jul 5, 2007 07:40 PM
Lpye
Apr 18, 2005 01:31 AM
