Lowering???
Old Oct 8, 2017 | 07:45 PM
  #41
fabricater's Avatar
fabricater
Originally Posted by OldPhat
fabricater----Who makes the lowering blocks that you got,
will help the rest of us short people who are 5'-7" or less.
John
https://www.jpcycles.com/product/700-485
I got mine at my local dealer. It's what they recommend. They are good for 1" drop but no more. They look heavy enough and made well. Mine came with all the hardware.
Old Nov 7, 2017 | 06:11 PM
  #42
Softy 103's Avatar
Softy 103
I see that pro action has a premium 14" shock that they sell that comes with 1" lowering blocks. Huuuumm. Must not be so bad after all.
Old Nov 8, 2017 | 11:24 AM
  #43
racerfranz's Avatar
racerfranz
Ive found the Slammer shocks are a bit harsh. Down the road I may look for something with more "long ride"comfort. I've gotten used to the controls, but may fool around with a slightly shorter shift lever. just a matter of personal taste, I suppose.
Old Nov 8, 2017 | 11:26 AM
  #44
racerfranz's Avatar
racerfranz
Originally Posted by Wodan
I'm taller but find the same thing to. They put all your weight on your *** bone too making you have to require a more heavily padded saddle.
There are a couple of companies that do mid-controls for FXR models and some for Softails. In theory they should be easily adaptable for FLHs as most of the dimension are the same. It would require machining a hole in the internal primary case and using a different inspection cover but it's doable and would make a big difference for you.
Have a look at Custom Design Studio, BOOSTED BRAD, Big Bear, Vulcan and others. They've all got bits that would help.
Also, have a look at the second generation FXR or FXR-P mid controls, they used a bolt on set up with footplates you could fabricate easily, someone else - can't remember the name - made a similar set up for Softails. I think they adapt Dyna mid-controls to fit.
Adapting Dyna mid-controls to fit would probably be the way to go.
The other thing to consider, if you don't know about them, are air shocks with onboard compressors. If I was short, it would be the way I went instead of a fixed lowering system which will kill you in the corners. There's one that automatically lowers, and then pumps up as you speed up. I've ridden with a lower kit and, frankly, found it so ridiculously easy to grind I removed it.
Just out of interest, H-Ds are really designed for big guys. Why did you go for one rather than a metric cruiser that would fit better?
Because metric cruisers have no soul. Haha. I've seen plenty of smaller riders on Harleys.
str hot rod
May 18, 2015 11:29 AM
jayzee75
Jan 4, 2014 11:30 AM
pattiann
Apr 7, 2010 03:55 PM
MasterGunz
Oct 30, 2009 10:53 PM
Wally
Jul 8, 2009 09:55 PM
