bearing puller?
Old Oct 6, 2017 | 08:08 AM
memphisharley's Avatar
memphisharley
Default bearing puller?
hey guys, looks like I installed my rear abs bearing in the wrong direction. what method and/or tool have you used to remove it. I'm not concerned with damaging the bearing.
thanks
Old Oct 6, 2017 | 10:32 AM
hardheaded's Avatar
hardheaded
pit posse puller and installer is what i have and bought it off e-bay. once you install one of those bearings it needs to be tossed if removed.
Old Oct 6, 2017 | 11:56 AM
memphisharley
thanks...yes...i'm definitely replacing the bearing.
looks like I can use a 7/8" concrete anchor to get it out. I'll post back if it works.
Old Oct 6, 2017 | 02:56 PM
hardheaded's Avatar
hardheaded
their is a specific way to install these bearings or they will be sideloaded and not last very long. good luck !
Old Oct 6, 2017 | 03:06 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Georges garage makes a good puller set for installing and removing these. Concrete anchor may work. Don't reuse. It will be damaged once it's pulled.
Old Oct 7, 2017 | 07:35 AM
skydude426's Avatar
skydude426
I have the tool from George's Garage. I've used it a few times and it works great. They have many other good tools as well.
http://www.georges-garage.com/chassis_tools.htm
Sent from my iPad using IB AutoGroup
Old Oct 7, 2017 | 08:35 AM
SG-Jay's Avatar
SG-Jay
I made a puller out of a 16mm allen head bolt. I ground the head back on an angle and cut it down the middle. It worked perfectly.
Old Oct 7, 2017 | 08:44 AM
uscanuck's Avatar
uscanuck
How did you get the original bearing one out?
Old Oct 7, 2017 | 12:08 PM
memphisharley
I got a takoff wheel that didn't have the abs sensor side bearing.
that said... the ole anchor bolt worked like a charm.
thanks to all for your suggestions.
rsking45
Wheels/Tires
Dec 6, 2017 02:57 PM
skully1200
Feb 13, 2012 09:09 AM
1/9AirCav
General Topics/Tech Tips
Sep 18, 2011 03:53 PM
Tarponrod
Exhaust System Topics
Dec 3, 2010 04:00 PM
fiveola
Shovelhead
Sep 22, 2008 07:35 PM
