'08 FLHTCU won't start after battery change
Old Oct 7, 2017 | 03:39 PM
PwnedNoob's Avatar
PwnedNoob
Default '08 FLHTCU won't start after battery change
I've haven't ridden in a while due to knee surgery. Bike has been in the garage for a while and I'd start it up every few months. Kept it on a trickle charger, but eventually the battery wouldn't hold a charge. Picked up a new battery, put it in and charged it up and now I can't start the dang thing.
The security system seems normal (chirps when ignition is turned off or on). I can here the fuel pump priming, but the engine cranks and never turns over. I have a Vance and Hines Fuelpak on the bike. I'm thinking it's something electronic, like when I unplugged everything to put the battery in, maybe something didn't get plugged in again. The bike has never been hard to start.
Maybe injectors clogged from sitting? I have the service manual -- any ideas for where to start troubleshooting? Thanks!
Old Oct 7, 2017 | 03:54 PM
cncmike's Avatar
cncmike
Won’t crank or wont start? If it’s cranking and there is fuel, does the exhaust have a strong gas smell? I would check all of the connections above the battery. Especially the ECM ( the big one). Then maybe all the fuses.
Old Oct 7, 2017 | 03:59 PM
PwnedNoob's Avatar
PwnedNoob
Thanks - it cranks strong but doesn't start. I'm thinking it's the fuel pack. I believe with the cover off and the ignition on, I should see my map numbers the LEDs and it's dead. That would seem to indicate it's not telling the injection system anything. Maybe I left something unplugged when I changed the battery (or blew a fuse). It was a lot easier in the old days!
Old Oct 7, 2017 | 04:04 PM
IrishHogtrotter's Avatar
IrishHogtrotter
You could try unplugging the fuelpack, and connect the standard harness to the ECU, and see if she fires up.
Old Oct 7, 2017 | 04:29 PM
PwnedNoob's Avatar
PwnedNoob
Great idea - eliminate the fuel pack. Just tried that and no diff. Since the FP seems to have no power and eliminating it from the equation made no difference, I'm thinking I left something unconnected when I swapped out the battery. Unfortunately, this drama will have to wait until the morning as I'm late for a family function tonight.
Old Oct 7, 2017 | 05:07 PM
IrishHogtrotter
also check the 'run/stop' switch is set right. Don't ask how I know. lol
Old Oct 7, 2017 | 06:33 PM
RollaMo's Avatar
RollaMo
But if that switch wasn't in the "run" position, the engine wouldn't be cranking as the OP states.
Old Oct 7, 2017 | 07:17 PM
RevBlk's Avatar
RevBlk
Probably dropped one of the leads when you installed the new battery. I've done it myself.
Old Oct 7, 2017 | 07:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
For giggles and grins, follow the wiring down from the crank position sensor to the plug, check for a connection, if it's connected, disconnect it, clean the pins re-connect. Try starting again. The Sensor reads the notches on the flywheel and sends a trigger signal to the ECM to fire the plugs. Worth a shot. Make sure the main ECM plug is seated and locked. Check the ECM power fuse, check fuse panel or owners manual for location.
Old Oct 7, 2017 | 07:52 PM
Boomer1143's Avatar
Boomer1143
Disconnect the fuel line from the tank and reinstall it. Give it a shot, doesn't take long to do.
