Performance baggers
Old May 26, 2023 | 12:00 PM
  #1801
Puglia10's Avatar
Puglia10
Originally Posted by Ratephi
question for those of you that raised they bagger by 1" or 2" (front and rear): apart from the increased ground clearance, have you noticed any improvements or negative impact on the overall handling of the bike? Any reasons why you would advise not to go this route? Many thanks!
Only downsides are:
-if youre short, it can be tough to hold the bike up loaded down, uneven surfaces, backing it up, etc. I'm +2" front and rear and 5'7" so its pretty tall for me, but growing up with dirt bikes Im used to it. Its just a lot heavier lol.
-Belt tension is a little harder to set due to the swingarm angle, but not a big deal.
-Pipe selection. A lot of full lengths will hit the axle nut - most are easy enough to fix via a big dent in the muffler to clear.
-Also the lean is a lot on the kickstand. Not really an issue, just harder to pick up. They sell kickstand blocks to fix that.
As you can see, a couple minor things but nothing major. Worth it in my opinion.
Old May 26, 2023 | 12:13 PM
  #1802
Almostinvincible119's Avatar
Almostinvincible119
Originally Posted by Puglia10
Only downsides are:
I haven't thought about the belt. You've now given me a reason to check adjustment.
I've considered the Bungking block but I think the lean looks good. I have also thought about adding a gloss black +1 kickstand to help it out.
Old May 26, 2023 | 06:46 PM
  #1803
DynaKid94's Avatar
DynaKid94
Raising the bike up was the best thing I've done to it. Coming off of multiple "performance" Dynas, my RK was an absolute pig at stock height. When I did the +2 front and 14" shocks, I was blown away at how surprisingly nimble it was, even feels more stable than my FXDXT.
Old May 31, 2023 | 11:01 AM
  #1804
Puglia10's Avatar
Puglia10
did a track day yesterday on my road glide. Honing some skills, learned a bunch and tons of fun! Try it if you can!
Palmer Motorsports in Massachusetts
Stock front tire was taking everything I threw at it. Stuck just fine.
+2” front and rear with mids, ground clearance still sucks…killing my pegs leaned over as much as possible
124”, +2”, ness mids, ness rotors. Stock calipers aren’t bad at all. Braking is much more important than power Tons of fun!
Old May 31, 2023 | 02:24 PM
  #1805
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
@Puglia10
Damn, raised your rig that much and still chewed your pegs! Not having your saddlebags on your rig, were you able to lean more?
Your tire looks like you were working the curves pretty damn hard! Curious, with your 124" hopped up motor. What was your top end in a controlled
environment?
What a blast. Looks like a fun azz track. How many laps were you able to get in?
YB
Old May 31, 2023 | 02:46 PM
  #1806
Puglia10's Avatar
Puglia10
Originally Posted by 09 YELLOWBIRD
@Puglia10
environment?
YB
Ha, yeah! I gave it all I could...started to scrape the primary so that was the limit. I might be able to lean off a little more with some more practice which would lessen the scraping. We'll see.
The bags were only off in case of a crash. I just figured itd be one less thing to replace. I dont think they wouldve scraped but maybe.
Top speed was only about 100 on the straight section. That first turn comes quick trying to slow the heavy thing down.
The track is great - a ton of elevation changes also which adds to the excitement.
I didnt count laps but I think it was 8 sessions at 20 min each. Probably about 5 laps a session so 40-45 total. Doesnt sound like much but it was plenty, its exhausting! I reset my trip before and it was 100 miles of track riding.
Old May 31, 2023 | 02:57 PM
  #1807
09 YELLOWBIRD
Simply BadAzz!
YB
Old May 31, 2023 | 06:41 PM
  #1808
2K10FBLO's Avatar
2K10FBLO
@Puglia10 congrats on the track experience. I need to get off my *** and do one. seems COTA runs them at holidays only which is kinda a PITA but I'll have to make do
Did you need gas or was 1 tank enough? I saw you said 100 miles, just curious if that was enough fuel when running at high speeds and high throttle. COTA is much bigger though so might and has longer straights so might not really be apples to apples comparison. Did you trailer to the track?
Old Jun 1, 2023 | 06:07 AM
  #1809
Ratephi's Avatar
Ratephi
Looks like you had tons of fun! :-)
Can I ask what risers/handlebar combo you are using and how tall you are @Puglia10 ? Thanks!!
Old Jun 1, 2023 | 11:51 AM
  #1810
Puglia10's Avatar
Puglia10
Its a lot of work and kind of expensive, but it is SO worth it! Money WELL spent. Ive spent more on footpegs, winshields, whatever...and they didnt teach me anything lol. Do it if you can!
1 tank was plenty (actually only used 1/2 tank which I was kind of surprised considering how hard I was pushing it, and the 124" is kind of thirsty. They did offer gas at the track also.
We did trailer there. Felt kind of odd trailering a bagger, but between the gear and it being over 2 hours from home if we had a bike break down, we decided to play it safe. Im glad we did because we had some shade, plenty of room for a cooler full of cold waters, and tools if needed. And it was a LONG day so it was nice to just drive home in the AC truck.
