ACR wire harness
Old Jan 9, 2018 | 06:59 PM
2014sportsteriron883's Avatar
Default ACR wire harness
Just picked up my ACR wire harness today for my 08 and the instructions are a bit vague to me can anyone explain how I go about hooking this up?
thanks in advance
Old Jan 9, 2018 | 08:52 PM
IKnowNot's Avatar
IKnowNot
What about them is vague?
I can tell you it is much, much easier to understand once you are looking at the wires, then just go step by step.
Route the harness by tucking it into the wire tray under the tank, leaving slight slack for movement.
(did you get the ACR Connector Clip?)
You should be able to see where the harness comes out of the tray on the right side, near where that clip would go. The rest comes out the bottom of the tray. Just try to shuffle the wires in the tray so they lay properly and aren't pinched or bulging.
As for hooking up the wires, basically you are taking the harness and putting it in series with the fuel pump fuse.
(you’ll have to skip step 4 under Install ACR Overlay Wire Harness because it is an 08)
One wire from the existing fuel pump fuse gets moved to an empty slot, then the two wires from the harness get hooked to fuse block, one to the now empty cavity of the fuel pump fuse, the other to the empty cavity where you put the old fuel pump wire.
The hardest part is getting the damn fuse block far enough away from the frame so all the wires can be installed properly in the back of the fuse block. Then the fuses would be installed in the front as usual.
Then the harness gets hooked to the ECM at cavity 19 via the third (V/GY) wire.
Hope that helps.
Old Jan 9, 2018 | 09:17 PM
Hope that helps.
Thank you!!! So when the 2 wires are moved to the empty slots do they now need a fuse?
Old Jan 9, 2018 | 10:20 PM
IKnowNot's Avatar
IKnowNot
Actually, in the fuse block, one wire gets removed, three get inserted (the one you removed and two from the harness)!
Say the fuel pump fuse is in slot 4, which has two wires. One connects to one side of the fuse, the other to the other.
You will be moving one of those wires to an empty slot ( # 3 which is directly above 4)
Then one of the ACR harness wires replaces the one you moved, and the fuel pump fuse can now be replaced.
The other ACR wire goes to the empty space that is left where you moved the fuel pump wire to (slot 3) then a fuse is put in slot 3 to connect the two.
Again, once you start doing it, it is much easier to see what is happening, especially since you don’t have to move those other wires that, on the 09 and above are in slot 3.
So instead of having an empty slot 3, and fuel pump fuse in slot 4, you will have a fuse in both.
The service manual should tell you how to remove the fuse bock, fuse block locks, etc. so the one wire can be pulled from behind the fuse block, then the three can be inserted from behind.
The fuses are inserted from the front as normal.
Old Jan 10, 2018 | 05:59 AM
Thank you I think I understand now
Old Jan 10, 2018 | 05:56 PM
Thanks again for your help I have the harness installed and it looks like it worksIt cycles on and off with the fuel pump I’ll have to wait until I get the heads back in to see if they work the way they are supposed to
Old Jan 10, 2018 | 08:11 PM
IKnowNot's Avatar
IKnowNot
I guess there was enough room to work behind your fuse block. It is a little tight!.
Old Jan 10, 2018 | 08:25 PM
It was a bit of a pain that’s for sure
beammeup
Electrical/Lighting/Alarm
Jul 26, 2018 06:08 AM
ultravista
11
Feb 28, 2017 11:28 AM
1931jamesw
Aug 21, 2011 04:01 PM
Man In Black
Feb 17, 2010 08:44 PM
chromedome
Mar 13, 2009 01:21 AM
