I have OEM cruise on my 2002 RK Classic. Worked perfectly. I changed out the front brake lines, pads and bars this winter. No issues there. When checking things out today the cruise will not come on. I ran the diagnostics and it returned Code 122 - "Front or rear brake applied".
I presume this is stemming from front brake work somehow. Any suggestions on how to proceed?
Are you sure that the brake light is not on? It's not uncommon for the front brake light switch to get damaged or misaligned when the switches are removed from the bars. AFAIK the only way that the cruise control would know that the brakes are applied is when the brake light is lit.
From the 2006 Electrical Diag Manual
Code 122 Application of Front or Rear Brakes NOTE May require inspection of brake levers or front brake light switch mounting Follow the chart above.
If pushing the front brake lever hard against the forward stop turns off the brake light, you probably broke the little plastic button off the front brake light switch. Just about THE MOST COMMON cause of cruise control failure, almost always following a grip or handle bar change. If you have throttle cables, there is a roll-off switch somewhere near the gas tank. Others say to pull the plug off that switch and try the cruise again. If it works, that is your problem. The roll-off is only one of about 4 or 5 ways to turn off the cruise, I never use that feature as it automatically causes a sudden lurch to closed throttle. You would still have the: front brake, rear brake, pulling in the clutch lever, turning off the cruise on the left side switch, and killing the ignition. Pulling the right side cruise switch to coast, or slow down position should disengage the cruise long enough to figure out some other way if needed. I still vote for the front brake lite switch as the most likely culprit. There are "shade tree" fixes not involving switch replacement if that is the problem.
This gets deeper... My brake light is not on inappropriately, and it functions normally using the front or rear brake. I can hear the relay clicking normally. I rechecked my connections at the Deutsch fittings, they are correct.
I had previously pulled one wire from the throttle cable switch, the cruise wasn't working but then did after that.
It's like the 122 code is stuck in the cruise controls brain. Can't imagine how, I had the battery disconnected per the service manual when I do work... Can I clear these codes? Can the dealer?
As I type this I'm remembering a trick us Jaguar XK8 guys do...disconnect both battery leads and touch them together for a few minutes. It helps clear memory we think.
It's showing like heck here now but what it may need is a good ride to get it "thinking" again.
Advice and suggestions are always welcome!
Yes, you can clear the code. Just keep the odometer button depressed while on the diagnostic screen that shows the code.
Still hunting for a cause and resolution. Visited with a HD Tech today, his experience - like many here - was to examine the front brake switch and assembly. I took it apart, verified the correct switch operation and wiring. All is perfect there.
I learned that on an '02 the dealer must clear codes but Cruise Control codes aren't like engine management codes and aren't "cleared". They are just present until the fault is resolved, then they disappear.
I got the throw-parts-at-it solution - try a new cruise control module - and the we-don't-know solution - just ride it and see if it starts working. Not much help, really.
There's not many more places to look, I may just wait until riding season here. I will, though, go through the diagnostic chart from 14GuineaPig. Thanks.
Sorry I gave you bad intell earlier, I was thinking 2004.
