front fork install?
Old Feb 10, 2018 | 07:09 PM
memphisharley's Avatar
memphisharley
Default front fork install?
ok... what's the tip on getting the forks back in. neither will line up to go into the top hole. it's about 1/8 inch off .
thanks
Old Feb 10, 2018 | 09:00 PM
memphisharley
scratched up my powder coated lowers trying to reinstall the forks. weird..they slid right out now they wont line up with the top hole. anyone have a clue? could it be because of the urethane bushings I installed...I didn't change anything else.
edit: got them in by loosening up the risers.
Old Feb 10, 2018 | 10:51 PM
BobFLHT2002's Avatar
BobFLHT2002
If i recall correctly, when I had mine off and on last year, I took one off at a time. I don't remember having any trouble getting them slid back in that way.
Old Feb 11, 2018 | 07:10 AM
Campy Roadie's Avatar
Campy Roadie
thanks
Off an 1/8" how?
What I'm driving at is when both tubes are out of the triple clamps you can move the clamps in and out of alignment. Hold the bottom one with the fork tube in it and pull the top one into alignment.
If that doesn't do it, try rotating the fork tube and see if it comes into alignment with the top tree. If it does, you may well have a bent fork tube. The best time to check for that is when it's disassembled with a dial caliper set up.
Old Feb 11, 2018 | 08:45 AM
dawg's Avatar
dawg
Like above, sounds like you may have turned the bottom bracket out of alignment. The top bracket merely sits on the stem so you probably turned it a bit, especially if pulling on the tubes to get them out. Were the pinch bolts loosened enough when you pulled them out?
Old Feb 11, 2018 | 08:47 AM
MURPHCC1's Avatar
MURPHCC1
he fixed it already........said he loosened up the risers.......he edited a reply.
Old Feb 11, 2018 | 09:23 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
You might also now want to look at why the riser are twisting that top tree 1/8". Those bushings must sure be hard or your risers are not the same length.
Old Feb 11, 2018 | 11:48 AM
Campy Roadie
Dial INDICATOR is what I meant to say. Glad you got it squared away OP.
Smokin 03
Aug 28, 2013 08:34 AM
tattoofever
May 21, 2013 07:18 AM
fenderzig
Oct 26, 2012 02:50 PM
brown dawg
Mar 11, 2012 10:20 PM
brown dawg
Mar 3, 2012 04:59 PM
