Axle Nut Torque Adapter
Old Mar 1, 2008 | 09:17 PM
rbabos's Avatar
rbabos
Default RE: Axle Nut Torque Adapter
ORIGINAL: Neckball
Bad technical advice, but to each his own... I prefer to put the proper torque on the wheel bearings.
That's good advice on a tapered roller bearing but that's not what is on the rear of a H-D. The only thing that is getting torqued is the axle and nut.
Did you throw the spacers away or something?
Ron
Old Aug 24, 2008 | 12:26 PM
Stank Slinger's Avatar
Stank Slinger
Mac tools part # KH9636 is same
Old Aug 24, 2008 | 01:54 PM
iclick's Avatar
iclick
FWIW, for those with SG's or anything with rear shocks 12˝" or less can do axle removal and re-install without special tools.
With the bike on the ground, place a towel over the muffler near the axle and loosen the nut with a 36mm socket. Then jack the bike up and remove the nut the rest of the way using the small 36mm wrench in the bike's tool kit, or by hand if loose enough. To re-install reverse this.
To remove the axle you will need to loosen the left muffler and push it down slightly to remove the axle. This is easy with 12" mufflers, barely doable with 12˝", but likely not possible with 13" shocks without dropping the left muffler. When knocking out the axle make sure the cam is at its shortest point as it passes over the muffler.
peddler
Mar 8, 2017 08:56 PM
SafetyMan
2014-2024 Touring Models
Apr 24, 2015 08:46 AM
Rickr01
May 3, 2012 05:56 AM
Willy G.
May 25, 2011 07:26 PM
Barton
Nov 14, 2007 11:18 PM
