Ohhh - oil wasn't in the first post - now I get it. I can guarantee you that you will not be disappointed with Energy One. I run their clutch with an SE spring and a Mueller Power Clutch ball and ramp. Awesome holding power with not a lot of effort.
I guessing this is not compatible with hydraulic clutch?
Switched to Drag Specialties oil... did not change out the clutch, the clutch was still slipping after I did maintenance.
Was considering the SE clutch kit, but looking at the Energy One website, going to call them tomorrow.
Highly reccomend the Energy 1. I'm running the Plus 1 Kevlar with heavy duty spring. It's a kit. Run Formula+ per E1.
We ride 2 up and aren't small people and it will snap your head back
You can use synthetic with the energy 1 clutch. I called them when I switched to the Energy1 +1 and heavy spring. They said they have had no issues running synthetic oil as long as it's not synthetic engine oil. I'm using Amsoil primary fluid in mine.
Please see the link below to Energy One's instruction sheet. It states NO synthetic fluid in giant bold letters underlined to boot.
On another note, I am sorry to hear you are running Amsoil
