Air pressure
Old Apr 6, 2018 | 09:28 AM
Dbruner's Avatar
Dbruner
Stage IV
Default Air pressure
What would be the correct air pressure for a Ultra Classic, Tires and rear shocks?
Old Apr 6, 2018 | 10:43 AM
Vernal's Avatar
Vernal
My 2014 36 front 40 rear 20-30 solo 40 - 50 two up.
What year is your bike?
Welcome to the forum.
Old Apr 6, 2018 | 11:07 PM
Nute's Avatar
Nute
Read the sidewall of the tire you want to chk/put air in. Recommended tire pressure will be written there.
Old Apr 6, 2018 | 11:36 PM
Ron750's Avatar
Ron750
This is wrong. We just had a thread on this.
https://www.hdforums.com/forum/road-...-pressure.html
Read this:
http://www.rollingthundercycles.com/page/482609976
The vehicle manufacturer takes many other factors into consideration when recommending the right tire pressure. Just putting the maximum pressure in , can be way off.
Old Apr 7, 2018 | 05:23 AM
doghead's Avatar
doghead
I used my owners manual for this info.
You can get them for free online from HD.
Old Apr 7, 2018 | 05:39 AM
PDB17UltraRG's Avatar
PDB17UltraRG
I ride mine 42 rear tire 40 front like to keep them high seems to give me the best tire life. Been doing this for the last 10 years never any problems. Start with your owners manual and play around with the pressures fine out were you like let and go for it.
Old Apr 7, 2018 | 05:44 AM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
From your other threads, I doubt you have the OEM tires. Non-OEM tires, always go with the tire mfg recommendation, usually found on their web site.
Not sure how old the tires are on your new ride, but check the rubber and/or mfg date on the tire as well.
Old Apr 7, 2018 | 12:12 PM
Budda109's Avatar
Budda109
For the rear shocks. How much do you weigh. What year is your bike? Are they stock shocks. Do you ride most often with max weight or the other way around? Never use a compressor on the rear shocks. Hand pump only. You will blow them/seals. Hand pump sold buy HD $50.00. Used they are around.
skizman
Wheels/Tires
Mar 12, 2017 08:12 AM
Ga Blue Knight
18
Aug 2, 2013 06:41 PM
TxCowboy
Sep 16, 2010 08:52 PM
clap
May 23, 2009 09:41 PM
tmitchellof PG
Dec 29, 2006 12:44 PM
