ABS Modulator Service
Old Apr 11, 2018 | 02:11 PM
67Customs's Avatar
67Customs
Stage III
Default ABS Modulator Service
Hi guys,
My bike is 2011 ElectraGlide Ultra. The ABS Modulator has a failure. Is there a way of servicing/repairing it??
Thanks
Old Apr 11, 2018 | 02:20 PM
GalvTexGuy's Avatar
GalvTexGuy
Nope and you can't even buy them anymore.
Old Apr 11, 2018 | 02:25 PM
Campy Roadie's Avatar
Campy Roadie
Here's the ABS ECU
https://shop.newcastlehd.com/part/40649-08
The HCU as GTG pointed out is dealer only.
Which unit of yours failed?
Old Apr 11, 2018 | 02:38 PM
67Customs's Avatar
67Customs
Stage III
Hi,
I took the whole module out.both controler and modulator.
The part number is 40601-08A but I have been searching for it and not finding it. Buying just the controler would do? Isn´t the problem in the modulator?
Old Apr 11, 2018 | 02:47 PM
Campy Roadie
Originally Posted by 67Customs
Hi,
It depends on what failed. If you have a hard lever or pedal it's the HCU, that is not available to the public.
If the failure is of the ABS ECU and you still have front and rear brakes, the part I listed will likely solve your problem. However, you'll still have the potential for a loss of either the front or rear brakes if the HCU ever fails.
Old Apr 11, 2018 | 03:04 PM
67Customs's Avatar
67Customs
Stage III
Unfortunately, my problem seems to be the HCU. Thank you very much for your help!!
Old Apr 11, 2018 | 04:03 PM
Vernal's Avatar
Vernal
eBay?
https://www.ebay.com/sch/i.html?_odk...odule&_sacat=0
Old Apr 11, 2018 | 04:05 PM
SBates08's Avatar
SBates08
Bypass it!!!!!
Old Apr 11, 2018 | 04:26 PM
FPV's Avatar
FPV
Might be one in there for 2013 on down (if so it won't be for long) but MoCo even managed to get all the used 48343-09 units omitted from eBay US. On the day they made that a dealer only item there were 13 available on eBay US but the next day they all had disappeared. If you log in through eBay CA (Canada) you can find them from US sellers but they clearly state they will not be shipped within the USA.
Old Apr 11, 2018 | 05:09 PM
14GuineaPig's Avatar
14GuineaPig
These videos gives some idea of what goes bad.
