86 FLHTC turn signal problem?
Old Apr 22, 2018 | 06:33 PM
elmo4fun's Avatar
elmo4fun
Default 86 FLHTC turn signal problem?
so... a couple of weeks ago i picked up an 86 FLHTC. ive been slowly doing work on it, making it mine, and sorting out issues that i find. the latest im not sure if its an issue or just how they are. the turn signals dont flash when the engine is not running (ignition on). when running they flash fairly slow. is this a flasher issue? or something else? or is this just how it is? im planning down the road to install a load manager and LED turn signals, but for now i need the stock stuff to work to pass inspection.
Old Apr 23, 2018 | 12:36 AM
Mr. Mike's Avatar
Mr. Mike
Doesn’t sound right to me. I’d spring for a new flasher module as they’re not that expensive.
Old Apr 23, 2018 | 08:57 AM
bagga's Avatar
bagga
auto parts store #552 flasher will work.
Old Apr 23, 2018 | 03:03 PM
grbrown's Avatar
grbrown
Wink
Your bike is thirty years old, so there may be a few age-related things causing problems. They can include any or all of the following:
  • corrosion in the bulb housings, so remove bulbs and if in any doubt replace with new,
  • poor ground at any or all light fittings,
  • corrosion in any of the wiring connectors - detach, clean and refit,
  • clean and refit wire connectors at the flasher unit.
You get the picture! In addition to the above, it sounds as if your bike starts OK, but the battery isn't giving a lot of power when not running. So in addition to the above disconnect both ends of both main battery cables, clean and refit - use dialectric grease to keep out the damp. Let us know how you get on.
Also be aware that we have a dedicated Evo section, where you can meet up with fellow owners.
Old Apr 23, 2018 | 04:18 PM
81rat's Avatar
81rat
grbrown is correct in every way
PLUS
GROUNDS H-D uses 18ga wire --way to small , over the years your bike is " Losing Ground "
A test-- run jumper wires from housing of bulbs to "NEG " post on bat -- see what happens
If your T/S are mounted on fiberglass saddle bags then ADD more ground wire to the lamps
Also chrome is NOT a good conductor of ground
Old Apr 23, 2018 | 06:27 PM
elmo4fun's Avatar
elmo4fun
thanks guys. i was figuring on alot of trouble shooting. and "ghosts in the machine" but wanted to know where i should start. thanks for the advise. and i will look up the evo section thanks
Old Apr 24, 2018 | 05:49 AM
grbrown's Avatar
grbrown
Talking
We have several new '80s Evo owners over there to meet up with, plus the usual crowd! We even occasionally have cake and coffee......
Old Apr 24, 2018 | 07:13 AM
Veekness's Avatar
Veekness
...cake and coffee, Mr. Brown?
Please! PLEASE!
LOL
Old Apr 24, 2018 | 07:24 AM
grbrown's Avatar
grbrown
Cool
Please! PLEASE!
LOL
Don't let this get out, but call by the P&Q thread......
That's your quest for the day!
Old Apr 24, 2018 | 07:27 AM
Veekness's Avatar
Veekness
A quest! I'm on it!
Tattooman67
Mar 13, 2014 10:48 AM
dankral
Jun 29, 2013 09:08 PM
BungoBill
EVO
May 31, 2013 10:54 AM
iceman0084
EVO
Jun 19, 2010 08:38 PM
scottdoege
Apr 5, 2009 06:20 PM
