Is it a DIY mod? The bke isn't under warranty so I don't have restrictions as to who does the work. I have built V8 motors which included installing cams. How difficult is it to install cams on my 2015 Ultra Limited? Do they need to be degreed like performance car engine builds?
They can be changed with the engine installed?
Just need to remove the tank and the intake manifold?
What all parts are needed? Push rods, rockers, etc.???
Where to buy cams and what are recommended for good all around performance that wont hurt drivability and MPG
There is a 103 cam thread in the Rushmore forum that will give you a lot of opinions about the off the shelf options available. As far as being a DIY mod, it's all nut, bolts and torque specs at the end of the day. No need to pull the motor, some don't even pull the tank, they just cut the stock pushrods and use adjustables for the install. Some HD specific tools may be required if you choose to upgrade your bearings while you're in there. Plenty of information on the forum and youtube if you search around. Not a job that a gear head should fear if you've done performance car builds.
From your post, I'd suggest you not try it yourself. While not a technically challenging job, it does require some special tools and skills.
You will also need a remapping of the computer in order to take advantage of s cam change.
Very generally, I'd suggest a mild camshaft profile. Yes, more radical camshaft profiles produce big and nifty looking numbers. But the engine becomes much more difficult to live with on the street, where you actually tend to want to gently chuff through town and such.
If you've done V-8's you can do the Harley. If you go to the Fuelmoto website there is a video on replacing cams that is excellent. The bigger challenge than replacing the cams is deciding which cams to put in. There are many choices and just as many opinions on which one is the best. Do your research and have fun working on the bike.
Wade: It's super easy for a guy who is not afraid to roll up his sleeves and "go for it". I would say that you should do 3 things:
1. Buy an service manual FROM HD if you don't already have one.
2. Decide where you want your cams to be making power
3. Talk to a couple of the reputable guys that sell kits and are also supporters of this website. You can't go wrong with Fuel Moto USA, or with Hillside. They'll sell you complete kits that will be fully proven for whatever you desire when all is said and done.
Its not a bad job, but the cams wont just fall out of the support plate. There are tricks to that but the most common is to press the cams in amd out of it.
I will only add that along with FuelMoto, S&S has a couple cam changing videos that are excellent too. If you've changed cams in a car, watch the video(s), get a manual and a couple of the special tools, you'll have no problem doing it yourself.....!!!
If you can turn a wrench on a car, their are enough videos on Utube, and vendors sights go help you get the job done. The real challenge is getting it tuned to take advantage of the new cams. Nothing worse than spending hours and money on your bike, then it runs worse because the stock map cannot adjust enough to the new cams. That's where places like Fuelmoto shine. They can provide instant support should a problem arise. Of course that never happens....lol. Good luck let us know how it goes.
Good luck!
To that list I would add:
4. Replace the crap Mexican lifters with some decent ones such as S&S Premiums.
