Barnett clutch slipping
Old Jun 26, 2018 | 01:35 PM
2014sportsteriron883's Avatar
Default Barnett clutch slipping
So I just put in a new Kevlar extra plate kit with se heavy spring this past winter and I’m running Lucas primary oil which is synthetic and I had it dynoed a few months ago after I did the 103 and headwork and it pulled 112 tq and 96 hp for the base tune right out of the gate
i took it in today after about 3000 km for some final tuning and now the clutch slips around 4500 wide open on a 5th gear pull and only put out 105 tq today due to the slipping
any suggestions? I was thinking going back to hd formula plus
Old Jun 26, 2018 | 05:08 PM
ORradtech's Avatar
ORradtech
I don't know what Barnett reccomends but I put in an Energy One kevlar +1 with their Heavy duty spring kit in 18 months or so ago. They reccomend not using synthetic and actually reccomend the HD Formula +. Mine's only a 96 running stage 2 and doesn't put out the torque yours does but it's actually hard to make slip even when I want it too.
Old Jun 26, 2018 | 06:19 PM
Veekness's Avatar
Veekness
When I replaced mine clutch with Barnett Kevlar, the literature recommended ATF, actually.
Old Jun 26, 2018 | 06:33 PM
BB59's Avatar
BB59
That extra plate clutch pack with the SE heavy spring should not be slipping at 112 TQ. I've run more tq on a lesser clutch set up.
Make sure it is properly adjusted in the primary. Lucas primary oil should work just fine.
On the other hand if it has been out of adjustment and slipping the entire time it could already be toast.
Old Jun 26, 2018 | 06:44 PM
jammerx's Avatar
jammerx
Make sure the plates are in the right order.
Old Jun 26, 2018 | 06:51 PM
ive never noticed it slipping until it went on the dyno mind you I haven’t been riding it that hard either
I pulled the plug and it was clean and smelled fine
i did adjust the clutch last week and did as I always do back off the cable and then turn the screw in the primary in until it just touches then half a turn out
Old Jun 26, 2018 | 07:28 PM
nobodyknowsme's Avatar
nobodyknowsme
I was advised that when I had my Barnett clutch put in that it would prefer non synthetic, FWIW.
jt metal
Jul 21, 2019 12:34 AM
Nov 30, 2017 01:29 PM
atrain68
Feb 29, 2012 07:52 PM
hydrolock43
Nov 29, 2011 02:24 PM
DI75
Feb 2, 2007 11:08 PM
