Dead battery
Old Jun 30, 2018 | 11:20 PM
Mmarkley's Avatar
Mmarkley
Stage I
Default Dead battery
I have a 2012 Electra Glide Ultra Classic. I replaced the battery with a brand new one. Every 3-4 days, my battery is dead. Any ideas?
Old Jul 1, 2018 | 12:22 AM
mmesa005's Avatar
mmesa005
Look at your fuse block and check behind each fuse and relay for moister or corrison.
Also good to check your charging system https://www.hdforums.com/forum/evo-c...ng-system.html
Old Jul 1, 2018 | 03:01 AM
CSMHOG's Avatar
CSMHOG
Never replace a dead battery without having your charging system checked or a milliamperes draw test. You may be replacing a component due to another system failure ... in other words your repairing a symptom failure not the cause.
Old Jul 1, 2018 | 07:38 AM
Spartanden's Avatar
Spartanden
agree....check charging system, and see if there are any open draws on your system. sure, you may turn everything off when you shut down, but there may be a short someplace or something pulling draw off battery.
Oh yeah....welcome from Spartan Country Michigan!!!
Old Jul 1, 2018 | 07:47 AM
Hoginedgewood's Avatar
Hoginedgewood
If you have a down season do you maintain during that time?
Does it sit for a week once in a while? If so does it start on it’s own?. If it had a slight drain that’s when it would show.
Old Jul 1, 2018 | 08:33 AM
PDB17UltraRG's Avatar
PDB17UltraRG
You can use a Battery Tender this will help keep your battery charged when not in use, but it sound like you already have some charging issues get your charging system checked out that were your problem is. Ride Sake Ride Alot
Old Jul 2, 2018 | 06:10 AM
lionsm13's Avatar
lionsm13
Voltage regulators for that year 2012 were notorious for going bad from what I recall.
Old Jul 2, 2018 | 07:05 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Charge battery. Load test recommended. If OK, properly install battery on bike.
Remove maxi fuse.
Connect known good digital meter, observe volt reading. If steady, proceed. If not, check battery.
Reinstall maxi fuse. Volts dropping? Proceed.
Pull fuses one at a time, looking for the problem circuit causing the drain.
Fix or replace culprit.
Old Jul 2, 2018 | 09:02 AM
Z's Avatar
Z
Did it do this with the old battery?
Rockdog4
Nov 23, 2018 10:44 AM
stein79
Electrical/Lighting/Alarm
Oct 28, 2016 08:55 AM
Savgator
Sep 22, 2010 05:24 AM
essentialcycle
Aug 8, 2010 08:26 PM
redskinsrock
Feb 21, 2010 05:38 PM
