Does this sound normal?
Old Jul 27, 2018 | 08:47 PM
ROCKOUT Rocker Products
Sponsor
People say you can't fix a problem with oil, and that's probably true. But you can mask noise with it.
When it comes to noise, as a rule dino oil is always quieter than syn. My personal choice is Spectro 25-60 dino.... when it comes to noise nothing comes close. The worst I've tried is Mobil 1 V-Twin 20-50... again, nothing else comes close.
I won't get into an argument.... in my quest to stop the top end tapping I tried a LOT of oils, I know what works.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 27, 2018 | 09:09 PM
jammerx's Avatar
jammerx
Ride it!
Old Jul 27, 2018 | 11:01 PM
Veekness's Avatar
Veekness
Randy, you may have hit the nail right on the head with your suspicionings about the cam. To me, you've got all the bases covered.
Old Jul 30, 2018 | 05:43 PM
Panzerfaust's Avatar
Panzerfaust
Randy,
Please check my original post, and tell me if you think mine has the same whine. Let me know.
Thanks!
Chris.
Old Jul 30, 2018 | 06:02 PM
cajun1957a's Avatar
cajun1957a
Panzerfaust, I listened to your vid and yours most definitely sounds like a primary that is so tight it is ready to break. Mine doesn't sound anything like that. I would go into your primary and check the tension. You can do that through the inspection plate on the primary. That being said, if your chain has the proper slack, you could have a bearing going on that side.
randy
Old Jul 30, 2018 | 06:03 PM
SBates08's Avatar
SBates08
Next time you rev the bike, put slight side pressure against the shifter lever and see if your rattle stops.
Old Jul 30, 2018 | 06:06 PM
Panzerfaust
Default Prinary slack
Check this video
Old Jul 30, 2018 | 06:18 PM
Panzerfaust
Default Tensioner slack
Here is the tensioner slack video
Old Jul 30, 2018 | 07:28 PM
Panzerfaust
Sorry, would not upload from phone. So try this.
Old Jul 30, 2018 | 07:33 PM
nytryder's Avatar
nytryder
Check transmission and primary oil level. How many miles since you bought the bike?
