fork options
Old Sep 28, 2018 | 04:37 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default What forks do you have?
Originally Posted by Drtumolo
Will the Intiminator Fork Valves work with the hd premium low front kit I currently have
You have a 2016 streetglide W/factory lowering premium suspension. There is nothing premium about the forks on your bike. In 2017 HD came out with the "Bending Reed" system which is a $1.00 more to manufacture than yours. Unless you modified your forks they are the exact same length as all of the other 2016 touring bikes.
I tried to sell the Ricor Intiminator but I test the product on an actual bike first. After re-Valving as well as using as is, I declined marketing this product. I did choose the Racetech cartridge emulators and correct springs which worked far better and the Ricor Intiminator & Racetech cartridge emulator are about the same in price. Of course the spring price is the same as both systems require the proper rate spring for the bike which are available numerous places. I do not install the Racetech cartridge emulator the same as listed in their instructions but the results are better. I have been selling these since 2006 so ask around.
Racetech cartridge emulators will never be equal to a real cartridge system. There are many cartridge systems out there and all are far from equal. Like all suspension, you can go through several systems until you find the one that works for you. There are many that costs a lot of money but there are few that measure up. Choose carefully and good luck.
"Will the Intiminator Fork Valves work with the hd premium low front kit I currently have"
PS, to answer your question, Yes.
Old Sep 28, 2018 | 06:09 AM
Drtumolo's Avatar
Drtumolo
To clarify I have the Low profile premium ride single cartridge fork kit part number 45500157 on my bike.
Old Sep 28, 2018 | 12:29 PM
FastHarley's Avatar
FastHarley
Former Sponsor
as stated, they will only work on the damper rod style and not the cartridge.
Old Sep 28, 2018 | 01:54 PM
todd-67's Avatar
todd-67
I have the progressive mono tubes in one of my bikes. It is better than stock but I wouldn't call it anything more than how they should have come from the factory. For what they cost they are OK but I wouldn't pay more for them. The legend kits have mixed reviews on. Some swear by them some say they are too stiff. I really think from where you are now the only real options what Howard listed out for you. There just are not the choices out there like there are for the rear end.
Old Sep 30, 2018 | 07:42 AM
lyork's Avatar
lyork
The Legends cartridges I had installed on my 2017 Ultra were stiff at the initial settings. I talked to Legends and followed their suggestions on adjustment. Now the front end is awesome. I wouldn’t shy away from the Racetech system either. I have no experience with the Intiminator Valves, but DK Customs is an outstanding vendor and I would suggest contacting them and discussing that option as well.
Old Sep 30, 2018 | 09:27 AM
KumaRide's Avatar
KumaRide
Had Ricor Intiminators in the softail and currently have Race Tech Springs and Gold Valves. The RT setup is far superior. You will have zero regret with Race Tech. However, it is not plug and play and should be setup correctly to realize the full benefits. The RT instructions miss the mark on best setup. $250 for everything - springs, valves, seals, oil... and the results in ride quality and handling are worth far more.
cc rider47
Ironhead
Sep 10, 2013 12:13 PM
SpicOfTheDevil
Mar 8, 2011 08:33 PM
sporty2003
Sep 2, 2008 03:08 PM
ROBSREDFORD
Jun 25, 2007 09:28 PM
MAX EVO
Nov 4, 2006 08:31 PM
