Starter kickback
Old Sep 30, 2018 | 08:27 AM
1Yardman's Avatar
1Yardman
Default Starter kickback
Just bought this 2007 flht and it came with the starter kickback. wow it sounds bad.but also has 90 day warranty and I bought the extended warranty 5 year. has anyone had this covered on there warranty. Thanks
Old Sep 30, 2018 | 09:14 AM
Bingee's Avatar
Bingee
The most common reasons for kickback are high compression, weak starter, starter clutch problem, compensator problem, weak battery, carbon build up, loose battery connections, a little of each. Solutions are several including compression releases, higher powered battery, new battery, new starter clutch, new compensator, tighten connections, starter button trickery... Doubtful if any of the above are warranty issues. There are lots and lots of threads about this problem. Do a search of the threads and read them. But it takes a lot of analysis ($$$) to track it down unless you can find someone knowledgeable local who can check it out in person. In other words you'll need a lot more information to track it down. It CAN be solved.
Old Sep 30, 2018 | 09:35 AM
1Yardman's Avatar
1Yardman
It works flawless if I hold starter button down as I turn the key switch. Doe's that narrow it down any ...thanks
Old Sep 30, 2018 | 02:35 PM
dickey's Avatar
dickey
The most common reason for this is old/weak battery, or loose battery terminals. Check that first; it's free!
Old Sep 30, 2018 | 05:24 PM
F150HD's Avatar
F150HD
Does it sound like this?
Old Sep 30, 2018 | 05:35 PM
1Yardman's Avatar
1Yardman
Unfortunately yes that is it. Now give me the bad news
Old Sep 30, 2018 | 05:56 PM
MURPHCC1's Avatar
MURPHCC1
dont wait so long to hit the starter button after ignition is on and hold that puppy till it's started. you're letting off the button too early.
Old Sep 30, 2018 | 06:07 PM
1Yardman's Avatar
1Yardman
It's been working by holding down starter button then hit key but today it didn't it's still under warranty so I'll see what they say thanks for the help.
Old Sep 30, 2018 | 08:34 PM
MURPHCC1's Avatar
MURPHCC1
try this instead.........do the opposite.........turn the ignition and wait about 1-2 seconds, then hit the button.
A few things have to be seen my the ecm for it to get into start mode., IAC, CPK, temp, MAP sensor, TPS.............holding the button while turning the ignition doesn't give the ecm time to see those things.
Mar 26, 2012 06:54 PM
AnniversaryFatboy
Jul 8, 2010 05:45 PM
bwanas
Oct 22, 2009 09:21 PM
Beauregard
May 22, 2009 03:22 PM
rotorhdh2
Jan 31, 2007 02:23 PM
