Lo rng
Old Oct 4, 2018 | 05:40 PM
jim crosby's Avatar
jim crosby
6th Gear
Default Lo rng
I just had this LO RNG code after filling my tank. Nothing would happen after that no start nothing. I turned the swtich to the off postion waited a few minutes. Then all was well...
Last edited by jim crosby; Oct 4, 2018 at 05:48 PM. Reason: Forgot model and yr FLHX 2015
Old Oct 4, 2018 | 05:43 PM
nobodyknowsme's Avatar
nobodyknowsme
Do you know how to check and clear codes? What bike?
Old Oct 4, 2018 | 05:52 PM
ve9aa's Avatar
ve9aa
no, no, no, that's not how this game is played.
We're all supposed to be psychic or really good guessers.
I'll go first. (question one of twenty)
Is it a 1942 WLA?
Damn, I think I might've just wasted my guess.
Who's next?
Old Oct 4, 2018 | 05:55 PM
jim crosby's Avatar
jim crosby
6th Gear
Default Lo RNG
HD SG FLHX 2015. I looked on goggle for some info. I ended up here. I had not had any issues with the bike and codes before.
Thanks for any help...
Old Oct 4, 2018 | 05:58 PM
Jshopes's Avatar
Jshopes
Low range. Mines done it before but it didnt disable anything. It just came on when i was low on fuel.
Old Oct 4, 2018 | 06:59 PM
Sam2010's Avatar
Sam2010
Low fuel AND low battery. check your battery connections make sure you have a good battery.
I've seen a couple few threads in the of few threads in the forums on this people were finding battery issues also.
Old Oct 4, 2018 | 08:21 PM
hattitude's Avatar
hattitude
I believe "Lo Rng" is a low range fuel warning. It could have been triggered when the bike unsuccessfully tried to start. Could be a 12V issue. Check cables and grounds, and make sure the battery is good...
Another thought. Maybe the "Lo Rng" was just a glitch due to the fuel fill up, and was unrelated to the lack of starting. Were the lights flashing? Could the security have been activated?
I ask about the security, because I've read where some people have issues in service stations, with interference causing the TSSM to not "see" the security FOB. They move their bikes a few feet, or wait a few minutes, and then it starts right up with no further issues....
Let us know if you find the culprit....
Old Oct 6, 2018 | 10:06 AM
HDpoppy's Avatar
HDpoppy
Stage I
2016 SG Special ....Got same problem speedo- Tach-volt meter sweeping engine light on sec light on ???? any help ??
Changed battery checked connections giving comm codes U0001-U0100-U0121-U0140-U0184 & LO RNG ....also had a burned out running light
nothing added or changed all factory
Old Oct 6, 2018 | 12:25 PM
hattitude's Avatar
hattitude
Those codse all involve a loss of communication between electronics on the CanBus. Those can be a nightmare to find. If you have have checked all the ground connections, as well as battery connections, you have eliminated a major potential source for those codes...
I have read about loss of communication due to pinched wires by the neck of the frame. I have read it involving pre-CanBus and CanBus bikes. Some complain it's due to small wire gauge issues, others believe some bikes come form the factory with the zip ties around wires at the neck too tight... in any case, might be a good thing to check since you have such a wide variety of components experiencing a comm loss..
For reference, i saved the link to this thread, read the first post....
https://www.hdforums.com/forum/ignit...bcm-codes.html
Lostsheep01
Sep 22, 2021 02:30 PM
Mugsy666
Aug 6, 2016 11:29 AM
kwn36
Sep 20, 2014 10:12 AM
xFreebirdx
Feb 10, 2014 03:05 AM
joee
May 22, 2012 05:29 PM
