Voltage regulator
Old Oct 15, 2018 | 08:12 PM
interceptor143's Avatar
interceptor143
Stage III
Default Voltage regulator
Has anyone ever had an issue with the voltage meter jumping from 14 amps to 12 and then back again? I have changed the stater, regulator (twice) and battery. I have checked all the wiring, No breaks or cracks) disconnected all my after market lights, stereo, and so on, but the problem persists. Any ideas?
Thanks
Old Oct 15, 2018 | 08:16 PM
Kingglide549's Avatar
Kingglide549
What are you testing it with?
Do you mean volts?
Old Oct 15, 2018 | 08:19 PM
interceptor143
Stage III
Yes, Sorry Volts. The bike was tested at LaneSplitter HD in San Jose. and they can't figure it out either.
Old Oct 15, 2018 | 08:24 PM
Kingglide549
Without being there and babysitting-
They are not using the bike gauge are they? !!!
Go buy a multimeter (under 16 bucks )
And put it across you battery and see for yourself.
If you are actually jumping back and fourth I would be surprised as electronic reg are faster then lightning.
Do that then then post what you get.
Old Oct 15, 2018 | 09:11 PM
MotoJockey's Avatar
MotoJockey
Not sure what bike you have, but I did experience something similar on my '14 SG just recently. Ended up being the DC Lead Connector on the bottom of the Regulator was intermittently making/breaking connection. The little plastic connector keeper was loose. Anyhow, the Volt Meter, yes...... the one on the bike....... would go back and forth between 14V and 12V, then it stayed at 12.....then 11...... then 10. Got me home, trouble shot the connector, got a brand new battery under warranty, all is good.
Old Oct 15, 2018 | 11:37 PM
rhuff's Avatar
rhuff
Wheel bearings have been found to. affect them. For real. Check it out over at HarleyTechTalk.
Old Oct 16, 2018 | 03:17 AM
Kingglide549
Yea right..
And the Moth Man told me to tell ya hi, as he passed a note to Bi Foot
Old Oct 16, 2018 | 12:01 PM
btsom's Avatar
btsom
Voltage regulators frequently become intermittent before total failure. If you can eliminate the stator and wiring, that is about all that is left.
Old Oct 16, 2018 | 12:15 PM
F150HD's Avatar
F150HD
what year and model? there was a recall on volt regs years back on the touring line. my 12 Ultra got one when mine failed. Volt meter would hop around on the gauge.
Old Oct 16, 2018 | 01:40 PM
pdog75's Avatar
pdog75
6th Gear
I had this same issue, but both the regulator and stator were Cycle Electric's. I found the issue to be one broken cable between the stator and the voltage regulator. I was cleaning the bike and saw the one broken wire out of the three. I re-soldered the cable, and everything is rock solid at 14.2 at cruising speed afterwards. No more weird fluctuations from 14.2 to 12 after this. I hope your issue is simple like mine.
Maybe recheck the actual cable itself between the stator and regulator?
