Stabilizer and solid bushings
Old Nov 21, 2018 | 05:03 AM
plumbers crack's Avatar
plumbers crack
Default Stabilizer and solid bushings
Got a great local deal on a Terry's Components stabilizer, wondering if I should still get set of bushings like sta-bo or glide pro? I've only read that most either use one or the other, haven't see both used.
Old Nov 21, 2018 | 11:36 AM
grbrown's Avatar
grbrown
IIRC your bike still uses the original cleve blocks in the swingarm. I use a True-Track kit with their swingarm bushings, can't comment on other brands, but definitely replace your bushings.
Old Nov 22, 2018 | 04:22 AM
plumbers crack
I'll be replacing everything in the pivot area, wheel bearing and shocks because the wobble is pretty bad at anything above 65. I'll get them, I'm coming from sport bikes so I'd like to get it as stiff as possible.
Old Nov 22, 2018 | 05:18 AM
Stiggy's Avatar
Stiggy
I've had my '00 FLTRSEI for awhile now (165,000 miles,) and at 100,000 I changed wheel bearings and motor mount / stabilizers. I used an early model (very stiff, took 500 miles just to break in,) front motor mount and these Nylatron swingarm bushings. (see link.) They tightened up the rear end quite well. Reasonably priced too.
https://www.jpcycles.com/product/433...rm-bushing-set
Old Nov 24, 2018 | 06:11 AM
plumbers crack
Has it still stayed tight after 65k?
Old Nov 24, 2018 | 10:40 AM
Stiggy's Avatar
Stiggy
Yes, Nylatron is used in bushings for both cars and trucks as O.E.M. I am currently looking for a good set of shocks but the swing arm is still tight.
Crazy
Jun 20, 2018 08:20 PM
Casper
Aug 16, 2017 07:12 PM
rauchman
Jul 29, 2015 09:10 AM
Rocko Rock
Sep 12, 2008 03:22 PM
twhitey
Nov 22, 2007 08:55 AM
