Drop in cinversion LED Headlight Bulbs
Old Nov 27, 2018 | 07:30 AM
btsom's Avatar
btsom
Default Drop in cinversion LED Headlight Bulbs
My complaint about the many sellers is that none show the beam projected on a wall. "Headlight Revolution" is a web site which demonstrates and sells LED drop in bulbs and LED "Sealed Beam" units and demonstrates each option they sell. They have made many videos and put them on youtube and depending on your level of interest, you can spend several hours learning what is important and which units perform well. I finally set aside some time and watched several of the videos. For those wanting to cut right to the bottom line, the GTR Ultra Generation 3 bulb most closely duplicated the beam pattern of the original halogen bulb and was also the brightest of the options. In one of the videos, I believe the presenter said the bulbs were available singly but the sales section made no mention of that option. I plan on waiting until after the holidays to make a purchase but in the mean time will Email HR to ask about a single bulb purchase, if there have been any reports of radio interference, and if there have been any reported difficulties in installing those bulbs in a Harley Road King reflector. With the only previous drop in LED I tried, the retaining spring had to be bent a bit to get it below the heat sink. HR also sows some 800 series passing lamp LED bulbs that may be too long to go in the Harley enclosure, I will inquire about those also. For those interested enough to learn why most brand X drop in LEDs provide bright but uncontrolled light, the answer is in there. Typically, the videos are "slow going" but I came away knowing considerably more than when I started. You can either go for the "full immersion" experience or go straight to the GTR Ultra Gen 3 evaluation to see what that bulb does and how HR evaluates them. I have no relationship with Headlight Revolution, haven't even bought anything from them yet, I'm just a guy thinking about better lighting for my old sled at a more affordable price and they seem to be a good source of information. When Googling for GTR bulbs, lots of brand X results come up, few actual sellers of GTR products, and the prices all seem close.
Curiosity pushed me to look at the sealed units also and I was surprised to see that both the JW Speaker projector unit and the Truck-Lite reflector unit were only "good" or "satisfactory", not "excellent" as I would have expected. Again, if you have the time and patience, the information is in there.
Old Nov 27, 2018 | 07:56 AM
caulk04's Avatar
caulk04
Ehh, even if they cut the price in half to $120 for a single bulb you're spending a bunch of money for something that I don't think is going to serve as well as a properly designed complete housing.
I have the Truck-Lite headlight and am quite happy with it. Very happy that it's USA made as well.
Old Nov 27, 2018 | 09:31 AM
jlb2782's Avatar
jlb2782
What makes you think that they wouldn't be just as good or better than a complete housing?? I am not disagreeing with you. Just genuinely asking is all.
Old Nov 27, 2018 | 09:40 AM
cprhed's Avatar
cprhed
I swapped my head and spots with LED bulbs from DK Custom Products. All 3 bulbs to my door for about a $100. They are just plug and play bulb swaps. They are not ridiculously brighter than stock but they do seem brighter when you look at them. My biggest plus on these is the color of the light they put out. It is more white than yellow like standard bulbs. I think this gives the perception of it being a lot brighter than it is. However, the light that is coming out of these matches perfectly to reflective road signs. I can see them reflected up to a 1/4 mile away. You get about 4 blocks from a sign and you would swear the sign has lights built into it.
I have never cared for the projector style on a bike because if you get off to the side you cannot tell there is a light on. I want to be seen.
Old Nov 27, 2018 | 09:48 AM
HM_SanDiego's Avatar
HM_SanDiego
Generally speaking, the led drop in bulbs have not been known to work well with the halogen bulb housing - the light source and direction on the led bulbs simply don’t direct the light correctly for the halogen bulb housiing. For this main reason, most people opt for the led replacement lights as a unit, so the led light source and the housing for it are designed to work correctly, emitting an appropriate beam pattern.
Another general issue with drop in led bulbs is the depth or clearance area needed for them in the housing. Sometimes the led bulb is simply too long or deep, and there isn’t enough room behind it in the housing.
Both of these reasons are why I have not installed led bulbs in my pickup (primarily the first issue related to poor beam pattern and reflection), but I am looking into them again, as I have read that there are better drop in led bulbs available these days (not simply bright but a quality beam pattern).
That said, I installed the Sunpie led headlight and aux light kit on my Road King, and I am very happy with the look and the performance, and for the price ($120 delivered for all 3), it is difficult for me to understand why some pay so much more for other options, especially when considering the led drop in bulbs which generally don’t perform near as well as the led replacement assembly.
Old Nov 27, 2018 | 09:50 AM
jlb2782's Avatar
jlb2782
Good info. Thanks.
Old Nov 27, 2018 | 10:43 AM
1LargeDog's Avatar
1LargeDog
I installed the Sun Pie lights as well. Very happy with them. It served it's purpose by lighting up the roadway at night better than the stock headlights at a great price.
Old Nov 27, 2018 | 02:05 PM
btsom's Avatar
btsom
" , especially when considering the led drop in bulbs which generally don’t perform near as well as the led replacement assembly. "
I provided the SOURCE material for a reason, DON'T bother checking and make your own decision...you can lead a horse to water... Periodically people inquire about purpose built and drop in conversions. There is photographic evidence and credible information, use or disregard at will.
Old Nov 27, 2018 | 02:41 PM
HM_SanDiego
Not to start an argument, but taking all of my comment in its entirety, one would see that the message there is that the drop in bulb technology has (historically) not been known to be the best performing, and in many cases, just poor performance.....
My comments were not intended to dispute your offered information, nor your impending choices, but rather to answer the other members question about drop in bulb versus whole projector led assembly.....
That all said, I offered my opinions as to why I personally had not chosen to purchase drop in led bulbs for my pickup previously, but, that I have been reading about improved drop in led bulb design and performance recently, and I am reconsidering because of the current offerings based on new developments......
I look forward to seeing and reading your results when you purchase and share your experience with drop in led bulbs on your Harley.
Old Nov 27, 2018 | 03:02 PM
btsom's Avatar
btsom
The web site I recommended tested both complete assemblies and drop in bulbs. The drop in bulb I am considering outperformed most of the sealed assemblies in the video taped tests. Because this was so different from past experience (and yours) I thought I would share the results, and the source of the results. Each interested person can then go and evaluate the testing method and the results for himself and decide based on their evaluations of the tests which way they want to go. I would respectfully suggest looking at the test yourself before condemning out of hand based on dated information. I tried to convey that in the original post. On occasion, technology does change and improve.
