front end wobble
Old Jul 3, 2007 | 12:35 PM
mark10's Avatar
mark10
Default front end wobble
i have an '07 ultra - just got it last april. rode a lot 30 yrs ago on a 750 honda with a windjammer fairing. don't remember ever having a wobble in the front end.with my hd - i amfeeling some wobble depending onspeed and wind. doesn't happen all the time, but is definitely there at times. haven't ridden this particular scoot enough to get a clear understanding of when where and why.was wondering if anyone else has felt the same. other than those times the bike feels really stable and steadfast.
Old Jul 3, 2007 | 08:04 PM
PhilM's Avatar
PhilM
Default RE: front end wobble
Under what condiftions are you experiencing this wobble (speed, straight/turn,)?
Are you talking about a speed wobble? Those typically won;t occur until 90'ish+ mph. Are you running that fast?
Old Jul 3, 2007 | 08:08 PM
Peekaboo Bob's Avatar
Peekaboo Bob
Also, keep in mind that the batwing will transmit wind turbulence to the forks. It's not a real wobble as much as a nervous feeling in the front end caused by the buffeting. You'll notice this more following big trucks.
Old Jul 4, 2007 | 05:08 AM
FL2007's Avatar
FL2007
Mark;
Could it be wind buffeting? I asked the same question recently. turned out a needed a taller windshield. Some people have added other deflectors to help. I suppose it could be mechanical. Ask the dealer to test drive it.
Old Jul 5, 2007 | 07:47 AM
mark10's Avatar
mark10
usually occurs like 50 -70. and, yeh, it almost is more of a 'nervous' feeling. i went out yesterday and tried to pay special attention for when exactly it happened. it only happened once for a little while. and it was, the best i could tell, had to do with the direction of the wind. and it was ever so slight. felt it worse at other times, but not yesterday. the bike itself didn't wobble. it almost reminds me of a flying one of those diamond shaped kites when it wobbles back and forth a little. or kinda like going over a screen bridge and you get that wobble, but not as bad as that. going out for a long ride on saturday and will have to see how it feels. want to check if the bars are really moving or just feels that way.
by the way - at 80 - 90, it is actually really smooth, no vibration buzz, no blur.
Old Jul 5, 2007 | 12:28 PM
casique's Avatar
casique
My RK Custom was wobbling all over the place this weekend, no windshield, at 80mph on I-95 (keeping up w/traffic).
Old Jul 5, 2007 | 03:40 PM
larry5h's Avatar
larry5h
I put the fork deflectors on mine,it seemed to help or maybe I just got used to it.
Old Jul 5, 2007 | 05:54 PM
Streetrunner's Avatar
Streetrunner
Mark, I had the same exact problem, usually a certain angle of cross wind would set it off. Scary as hell!
I think I have the issue solved. I installed the Touring XR stabilizer. I'm now scrapping floorboards. It made a big difference in the feel of the bike. Since the install I have not had the problem butIt's only been a few weeks so time will tell.
Old Jul 5, 2007 | 11:43 PM
boiserider's Avatar
boiserider
Low air pressure in rear shocks will cause nervous frontend.Pressure on the high side of recommended
pressure will give much better handeling. I ride solo on 07 ultra and I run 15 PSI in the rear shocks. Try it you'll like it. If you don't have the H-D pump you should get one. They are only about $40.00.
dixonk
2014-2024 Touring Models
25
Jul 27, 2015 06:08 PM
Duffyone
27
Jul 1, 2014 10:01 PM
R_W_B
Dec 10, 2010 02:26 PM
questor
Oct 21, 2010 03:26 PM
Mountainkowboy
Mar 20, 2006 03:16 AM
