Wheel Bearing life expectancy?
Old Mar 20, 2019 | 08:58 PM
BadDogBiker's Avatar
BadDogBiker
Default Wheel Bearing life expectancy?
I just got my 16 Road King back from the stealer and they say the tech heard a noise up front and says my wheel bearings are going out. The bike only has a little less than 27k on it. What's the average life expectancy of those? The bike does have ABS.
Old Mar 20, 2019 | 09:30 PM
dawg's Avatar
dawg
It can be a crapshoot on wheel bearings nowadays, especially if high pressure water washing is introduced into the picture. I’d certainly check them and change if they sound/feel like they are going south.
Old Mar 20, 2019 | 09:36 PM
Scout's Avatar
Scout
I've had 60,000 and I've had less than 10,000. Can't run with bad bearings, and they are cheap. It is what it is.
Old Mar 20, 2019 | 09:58 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
With enough good grease from the start - long life.
Not enough grease at the start - short life.
Pays to check bearings prior to install. Pop the seals and react accordingly.
And don't use a pressure washer on your bike.
Old Mar 20, 2019 | 10:05 PM
Wizardofaus's Avatar
Wizardofaus
I read some guy on here changed out the original wheel bearings for better units at his first tyre change.
Then every 10,000 miles after
Wiz 🍻
Old Mar 20, 2019 | 10:07 PM
BadDogBiker
With the extended warranty it's only going to cost $50 might as well get it done. Thanks
Old Mar 20, 2019 | 10:36 PM
Bone Doc's Avatar
Bone Doc
I have new wheel bearings installed every other tire change which, for me, is about 12000 miles on the rear and 20000 miles on the front.
Old Mar 20, 2019 | 11:11 PM
NORTY FLATZ's Avatar
NORTY FLATZ
My original rear wheel bearings began to saw the outer race in half. And, 100 miles later, they did. Destroyed the rear wheel/brake caliper/rotor/caliper mount/pads. Did all this in 6200 miles. No rain, no pressure washer, no wetness of any kind. No "two-up" riding. Just me (I go 230#.) Replaced all under warranty. Replaced with an "upgraded" bearing from HD. Front has been fine since new. 18,7XX miles now.
Old Mar 20, 2019 | 11:25 PM
BadDogBiker
Thanks for the replies, I had no idea they wore that quickly. Will be definitely be getting it done with a quickness I have suffered long enough without being able to ride.
Old Mar 21, 2019 | 04:31 AM
todd-67's Avatar
todd-67
From what I have experienced on my own bikes and witnessed with friends bikes the fronts are between 15-25K. Fronts I change with tires. Rears every other tire change.
