Voltage Regulator?
Old Apr 6, 2019 | 04:11 PM
Vernal's Avatar
Vernal
Pkman,
Welcome to the Forum from Utah.
A voltmeter at the battery is your best test. And while you're in there clean the terminals and check the grd cables to make sure they have a good clean grounding surface and are tight.
The electric diag. manual says anything over 15 V can cause damage. Like the others have said, Once you know the battery and grounds are clean and tight you could use the + lug on the battery or Battery tender plug if you have one to check voltage. Our bikes run right at 14V when running down the road and the gauge has fortunately been spot on.
Old Apr 6, 2019 | 05:09 PM
woodthumb2's Avatar
woodthumb2
the gauges are usually very close... i would dbl check with meter at batt or on tender pigtail but if me... i would go ahead and replace VR anyway...they can be spotty for sure... mine acted up for almost a year before i fired up bike one morning and volts were at 10... tapped VR with hammer and they jumped to 14... they can regulate low or high when failing.. most of time high tho
Old Apr 6, 2019 | 09:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
For really quick checks for voltage, I take the reading from the tender pigtail. Pos. lead in the protected opening and ground to chassis. E-z P-z
Old Apr 14, 2019 | 07:28 PM
Pkman's Avatar
Pkman
Follow up and thanks for all the replies - I don't think my digital multi- meter is the most accurate, but checked at the battery this weekend and it is right at 14.3 - 14.5 at 2500 rpm so I think I'm good. The gauge is not as bad as I thought either - just really hard to read with a helmet and bi-focals��
RideFree1267
Electrical/Lighting/Alarm
Nov 28, 2017 05:05 PM
rhuff
Sep 17, 2017 09:33 AM
thirsty
EVO
31
Jun 14, 2015 05:18 PM
greggmig
Apr 19, 2015 08:05 AM
mwriggs
Jul 25, 2012 11:41 AM
