Polishing Rotors
Old Apr 16, 2019 | 11:39 AM
Groucho-17SGS's Avatar
Groucho-17SGS
Default Polishing Rotors
I am considering polishing my rotors while on the bike. Why you might ask? I am not comfortable removing and reinstalling the front wheel. I do not intend to polish the area the pads ride as it will just be scuffed up again anyway. Basically I am pull one bolt at a time and polish the rotor using sandpaper working up to 2000 grit wet sand. Then install a chrome or polished stainless bolt and move to the next one. I plan to mask everything else off to prevent damage. Anybody else tried this?
Old Apr 16, 2019 | 01:41 PM
ZachE's Avatar
ZachE
Buddy of mine did that with his fork lowers, ended up bumping the die grinder collet up against a wheel rim and was less than pleased with the collateral damage...
Old Apr 16, 2019 | 01:46 PM
harkon's Avatar
harkon
Removing the front wheel is a 10-20minute job. Nothing that I'd say is too difficult. I will say though, if you are uncomfortable with removing and re-installing the wheel, you may be better off not tackling this at all. The likelihood of this turning into something you'll regret is pretty good. Personally, I'd believe this is nothing that should be done with the rotor mounted even on the wheel. JMHO.
Old Apr 16, 2019 | 03:55 PM
Groucho-17SGS
Thanks for the feedback. It's not that I am not mechanically inclined, I have performed lots of work on mine and my wife's bikes. I just don't like to fool with one of the two things keeping me attached to the road. Harkon you mention that this should not be performed with the rotor even attached to the wheel, not challenging but can you explain why?
Old Apr 16, 2019 | 06:21 PM
SWThomas's Avatar
SWThomas
You should remove the rotors. It’s really really easy.
Old Apr 16, 2019 | 07:13 PM
FlamedFXR's Avatar
FlamedFXR
Rotor bolts are one-time use. Get new ones either way.
Old Apr 16, 2019 | 08:28 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Hopefully, you will not get any grit or residual compound material into the wheel bearing. Even though it has a seal stuff grit can do strange things at 60 MPH. bst to remove the wheel and then the rotor to polish it. You may be better off just buying polished rotors and installing them. Good luck!
Old Apr 16, 2019 | 10:27 PM
Highwaymans's Avatar
Highwaymans
Daymmmmm.... You literally added an extra days worth of work vs just removing the wheel AND the discs from the wheel.... You do realize rotors arent aluminum, right???? Good luck with that.
Old Apr 17, 2019 | 05:27 AM
caulk04's Avatar
caulk04
Since you're familiar with a wrench, just pull the wheel. It's really not a big deal. Take your time, ask questions if needed and you'll learn something.
No they aren't. The factory bolts are 'one time' because of the pre-applied loc-tite. Harley's own chrome bolt kit says to apply your own and has no mention of one time use only. The torque spec is well below the yield point of a bolt that size.
Old Apr 17, 2019 | 08:48 AM
Rob175's Avatar
Rob175
As an aircraft owner, I changed out my standard wheels/rotors with "chromed" ones years ago. The chromed ones greatly extend the life of brake pads, which on aircraft are crazy expensive! I wonder if chromed rotors are available for motorcycles??
