Lost My Grip (or Get a Grip?)
Old Jun 14, 2019 | 04:52 AM
rozemab's Avatar
rozemab
Angry Lost My Grip (or Get a Grip?)
I noticed my right grip has loosened from the tube. Must have moved after pushing my bike in the garage.
Can this be repaired with glue etc ? Or it is a lost cause, ready to slip again?
My plans are to remove the assembly and attempt to re-glue the grip back into position. (Any gotcha's I need to be aware of removing the throttle tube assembly?)
FLHRC 2009
Old Jun 14, 2019 | 05:59 AM
Screamin beagle's Avatar
Screamin beagle
Funny thing is I have those exact grips and mine does the same thing. I just push it back on. It's been good so far this season with exception of when I got it back from the dyno dude...it had about a half inch gap, he must have been having fun. Sorry I'm not much help for a solution
Old Jun 14, 2019 | 06:01 AM
Dan D.'s Avatar
Dan D.
Just replace them. Changing grips is about the cheapest and easiest thing to do on these bikes.
Old Jun 14, 2019 | 08:13 AM
barneyboy's Avatar
barneyboy
Hair spray.
Old Jun 14, 2019 | 08:52 AM
hdbob2006's Avatar
hdbob2006
3m black weatherstrip adhesive is the only thing I have found to hold them on. It's usually the left one that gives you problems.
Old Jun 14, 2019 | 09:32 AM
larsfum's Avatar
larsfum
A lot of people use hairspray. I have always used 3M weatherstrip adhesive. Makes it tougher to get off, but then I don't change grips unless they are worn out. They never come loose unless I pry them off.
Old Jun 14, 2019 | 09:54 AM
J_MOSH's Avatar
J_MOSH
I'm with Barney. I've always just used cheap hairspray to hold grips in place. Cheap, easy enough to remove when I want and it works pretty damn well. Worked on motocross bikes that take real abuse, has worked just fine on my Harleys too.
Austin Dave
Feb 4, 2012 08:46 PM
straps
Mar 15, 2011 07:03 PM
Tri glide 10
Jan 23, 2010 09:02 AM
Kansasjase
Oct 30, 2009 07:05 AM
wayne72472
Jan 19, 2009 12:00 AM
