DIY seat reshaping
Old Jun 17, 2019 | 10:47 AM
67Shuv's Avatar
67Shuv
Default DIY seat reshaping
Has anyone ever tackled this themselves?
Ive got a new cover for an old stock seat that’s sitting on the shelf in the shop. I’ll swap the cover myself, that’s easy enough but while I’m there I’ve toyed with the idea of modding the stock seat foam a bit. Any tips/tricks for this? I know most everyone will say to send it somewhere but I can’t see this being real difficult, and will cost nothing. If I screw it up, oh well, it’s an old stocker. If it comes out great, even better!
Old Jun 17, 2019 | 11:05 AM
LJLKRL05's Avatar
LJLKRL05
I did mine on my ultra classic and I am pretty happy with it. I cut it down about 1.5" and added a gel pad and then some memory foam on top of the gel. Narrowed the front a little so I can be more flat footed at stops too. I am going to take the cover off one more time and add another 1/2" of memory foam to it.
I used an electric knife to cut most of it down, and a box knife and a grinder with a cutoff wheel to shape the spot for the gel pad. Also used the grinder to shape the foam after gluing the memory foam on top.
I bought a sheet of 1/2" memory foam and just added two pieces together to make 1" foam on top of the gel.
Just go slow and it is not that difficult. I used 3m spray adhesive to glue the foam together.
It does make a mess so do it somewhere easily cleaned up.
I did buy an air stapler from harbor freight because my electric one was not quite strong enough to neatly do the staples in the seat pan.
Old Jun 17, 2019 | 11:37 AM
FrankEV's Avatar
FrankEV
Where did you get the gel pad and what sizes do they come in?
When you narrowed the front it a little, did you actually mod the pan or just the foam?
Thanks
Old Jun 17, 2019 | 11:48 AM
LJLKRL05's Avatar
LJLKRL05
Thanks
I bought this gel pad, but mine was cheaper when I bought it:
https://www.ebay.com/itm/180579963745
There are lots of places to get the gel from though if you do a search.
I only cut the foam. I figured if I needed to cut the pan I would do that after testing it for a while. There was a white piece of foam covering it all when I took it apart and I put it back on after I did my mods.
Old Jun 17, 2019 | 12:14 PM
67Shuv's Avatar
67Shuv
Sounds simple enough. I would like to cut mine down and add some gel.
Old Jun 17, 2019 | 01:01 PM
FrankEV's Avatar
FrankEV
Thanks, looks like an easy project.
Old Jun 17, 2019 | 08:14 PM
xcbullet's Avatar
xcbullet
I've done like was mentioned but also you can grind out a curve in the center for the prostate some bicycle seats come this way, I'm saprised I don't see this on the after market seats at all.
Old Jun 17, 2019 | 08:24 PM
Sam2010's Avatar
Sam2010
I have narrowed and lowered stock seats reshaped a mustang touring seat once. I do not enjoy seat work. Tips or tricks go on YouTube plenty of how to's.
Old Jun 17, 2019 | 08:42 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
https://www.rushracingproducts.com/cyclepedic.html
Old Jun 18, 2019 | 01:54 AM
xcbullet's Avatar
xcbullet
All right never seen that seat before
Rob175
May 17, 2019 09:02 AM
JHC210
Apr 23, 2016 09:15 AM
Bumbobee
Jun 21, 2010 07:04 AM
dynalowrider07
May 21, 2008 08:19 PM
OneBlackFly
Mar 1, 2006 11:43 AM
