Gear indicator
Old Aug 8, 2019 | 09:27 AM
wolfvon's Avatar
wolfvon
Default Gear indicator
Does anyone know if Digital Gear Indicator KN000K00 from KOSO works on a Electra Glide FLHTP 2011 and if it does, how's it connected? On the outlet from diagnostic socket?
Old Aug 19, 2019 | 01:51 PM
wolfvon's Avatar
wolfvon
Got the answer myself. Got one gear indicator from China for less than $23 incl, shipping. Connected the indicator to the diagnostic socket and made a test run with gear change 1-6. The indicator followed every exchange and was working perfect.
Old Aug 19, 2019 | 02:03 PM
Big Dave's Avatar
Big Dave
A link to the $23 one please , I cant justify $150+ for the KOSO
Thanks
Dave
Old Aug 19, 2019 | 02:09 PM
Prof Rene's Avatar
Prof Rene
interessted as well for my wife's 08 FLSTc
Old Aug 19, 2019 | 04:28 PM
GregGillette's Avatar
GregGillette
I used this on my 13 FLHTC. Setup quite easy and works well. Very bright too. There are handlebar mounts but I mounted mine mid fairing between the big guages. Only issue is that when clutch is in, it doesnt show the gear so if you are at a light and forgot to downshift, it wont help you there.
Attached Thumbnails Gear indicator-screenshot_2019-08-19-16-16-06.png   Gear indicator-20190819_162415.jpg
Old Aug 19, 2019 | 05:13 PM
Sam2010's Avatar
Sam2010
FYI
Built-in Harley shift indicator like on 2014 and up when clutch is pulled in you can't read those either.
Old Aug 19, 2019 | 08:41 PM
Prof Rene's Avatar
Prof Rene
Originally Posted by Sam2010
FYI
I have the HD combo gauge on my 06 and when the clutch is in it does not show gear either.
Old Aug 19, 2019 | 09:14 PM
harkon's Avatar
harkon
Like the one in the PowerVision tuner gauge set, the ECU compares the road speed with the RPM and extrapolates the gear you must be in, and reports that via the data bus. It's why these things don't work when the clutch is in and RPM doesn't match a speed / gear combination.
Old Aug 19, 2019 | 09:18 PM
TriGeezer's Avatar
TriGeezer
Thats because they compute the gear by dividing RPMs by speed. So, anytime the clutch is pulled in, the computation is non deterministic, as you can rev the RPMs without affecting ground speed.
Old Aug 20, 2019 | 02:53 AM
wolfvon's Avatar
wolfvon
I bought it from this place: https://www.aliexpress.com/item/3297...12124c4dLx9zGz
Choose indicator for Harley.
