Weird throttle control on my 07 RK
It doesn't have tensioner. But you could probably find one. But I suspect that ain't it.
Maybe lube cables and bar. But I suspect just need to ride it.
Does it have cruise?
Also people add those tensioners to jap bikes after market.
Speaking from my bowels, I don't think you will like the bike. Maybe you'll relax and get used to a bigger bike. Maybe not for you. No shame in that.
I have an 07 myself.
Maybe to much drag as has been mention. Hell maybe add some. I like a little so I can take my hand off or a second without it jerking as slows down. So maybe try adding just a little. If you have no drag, it will start to coast sorta.. I can feel that.
Also what RPMs are you at? My 07 with stock primary chain tensioner flet like it vibrated under 3k. Plus is still kinda doggy under it. Ride it for awhile and see. Maybe get used to it, maybe change thing up, maybe lube it up. Dunnp.
It is also alot bigger and heavier bike than what you came from. Maybe that is effecting how it feels. RPM range different too.
Just read selling. They'll make more. As you said not attached to it yet anyway.
thanks for your help,,,,I'm just one of those **** mechanics that come out of the automotive world that thinks he can fix everything..
