Spark Plug Help Please
Old Jul 18, 2007 | 09:11 AM
blackfinbob's Avatar
blackfinbob
Default Spark Plug Help Please
I have an '07 Ultra and have not bought a service manual yet and the information I need is not in the owner's manual. Can someone give me the gap? I usually hand tighten the plug and go a 1/4 turn but is there an in/lb or an nm torque setting? Yes I promise I will go out and buy the manual. I searched throught the diy forum and can't find this specific information.
Thanks,
b
Old Jul 18, 2007 | 09:20 AM
gunrunner's Avatar
gunrunner
Default RE: Spark Plug Help Please
I think the Plug gap info is in your owners manual best I remember.
Old Jul 18, 2007 | 09:24 AM
ezlife's Avatar
ezlife
I have an '07 RK Classic.
.038 - .043 gap, 14-18 ft lbs. torque on plug 6R12. Probably same for you on 96 ci.
Always gap mine to .040, and torque to 18 ft lbs. they're close to that gap out of the box, but you still need to check and tweak as needed.
Ez
Old Jul 18, 2007 | 09:30 AM
blackfinbob
Geez,
It helps if you look in the right place......Thanks for setting me straight gunrunner.
b
Old Jul 18, 2007 | 10:28 AM
Kahuna's Avatar
Kahuna
I gap mine at .040 as well. Make sure you use some thread anti-seize as well.
Old Jul 18, 2007 | 11:30 AM
jumpmasterjay's Avatar
jumpmasterjay
Why are you changing your plugs already? You already have 10K miles? If so DDDDAAAAAMMMMMNNNNN, you are my hero!
Old Jul 18, 2007 | 02:26 PM
myglide's Avatar
myglide
If the 96 in. engine takes the same plug as a 88 in. engine in the softtails, then you can use Autolite 4164 from Checkers and save yourself some bucks. The guy at the dealers says they are the same, but all the looking and hum hawing he did I'm not too sure he knew.
Old Jul 18, 2007 | 06:58 PM
curmudgeon's Avatar
curmudgeon
.040 hand tight plus 1/2 turn.
I buy Champion 810 RA8HC from VIP auto for $1.70 each. I keep a spare pair with me with the gap and torque written on the box.
'00 RKC
hdwd2000
May 25, 2017 08:37 AM
glarior
Feb 24, 2017 09:38 PM
vanzant68
Sep 22, 2014 01:24 AM
HogNewbie
Sep 18, 2009 08:03 PM
mile high king
Jun 2, 2008 04:55 PM
