Dumb ? Time
Old Jan 20, 2020 | 11:12 AM
hattitude's Avatar
hattitude
Originally Posted by Big Dave
Winter Questions
This year i'll turn over 100,000 on the bike and have been thinking what I want future wise
Build my motor into a nice 107 --$4000 or so
Trade in for new ---$16-20,000 diference
Or drop in a new 131 M8 ----$8-10,000
Dave
You forgot one other choice....
Drop in an S&S 124" crate engine--- about $10K all in.. (crate engine/install/engine peripherals/clutch enhancement/dyno break-in/tune
I just had FuelMoto install their version of the 124" S&S engine that comes with their "outlaw" heads (S&S Super Stock castings, CNC machined ports with max torque emphasis), into my 2016 FLHTCU.... I now have max 136HP and max 151TQ with a great torque curve....
I'm very satisfied...
Old Jan 20, 2020 | 03:00 PM
Vernal's Avatar
Vernal
Yes I use Ronnies a lot but if there was just one tab change on the frame it would be a different part number
Thanks
Dave
Dave,
Ronnies is still a good source to compare a 2009 to a 2018 to see what's changed. If you compare the swingarm they are the same, spacers, bearings but the shaft is different . good chance the transmission would fit. Compare the Transmission oil pan gasket between the 2 years and there is a difference in shape.
The front motor mount is quite a bit different, looks like they changed in 2017. Any chance the 18 end cap would bolt on your 09 frame? If it would what are the chances the engine would fit?
2009 https://partsfinder.onlinemicrofiche...BILIZER%20LINK
2018 https://partsfinder.onlinemicrofiche...BILIZER%20LINK
Too bad there aren't spec sheets that show dimensions so you could compare frames and see what has been changed.
I thought if there were minor changes they kept the same part number and changed the - number or added a letter to the dash number. Major changes were given new part numbers. But with the frame the change could be in the steering head.
I know this doesn't answer your question but I hope it helps.
Old Jan 20, 2020 | 03:03 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by 62hdbiker
I replaced my motor with a S&S t111. Great crate motor for $5800
Thats probably the route I’d take.
Old Jan 20, 2020 | 03:04 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by rhuff
Yeah, the M8 isn't fitting.
Either build yourself a 107 or, you could build yourself a 131" from an S&S block. Gonna run you close to 10-13K when you're done though.
Just get a new bike for 16-20K if you can swing it. 11 years newer, my man.
I’m not so s7re about the 11-13 to swap in a crate motor. Your numbers seem high.
Old Jan 20, 2020 | 04:00 PM
skydude426's Avatar
skydude426
It would be nice to have the specs on both frames. In just looking at a picture of the two, they look basically the same. That doesn’t mean they measure the same. You could drop in a Fuel Moto 124”
https://www.fuelmotousa.com/i-238972...aw-engine.html
bormand85
Jan 3, 2018 10:43 AM
VINNIE JAMES
Apr 10, 2013 01:15 PM
S2NAZ
Apr 1, 2013 08:27 AM
mmcbeat
Mar 18, 2011 07:37 PM
g money
Jun 25, 2009 10:14 PM
